Question about Aprilaire 700 Humidifier
I replaced the water panel on my Aprilaire 700. Now it doesn't switch on. Help.
    Sergeant:
    Novelist:
  • 185 Answers
Did you get the plug back together. And did you plug it back in. Also make sure the Humidistat is set right. Here is site that might help you. Hope this helps.
http://www.aprilairehumidifierparts.com/aprilaire_humidifier.php?model=700&gclid=CLy4zffHnKYCFVZc2godEC51nQ
Posted on Jan 02, 2011
  • ashish_kaura Jan 03, 2011
    Thanks for the response. The problem was with the furnace which wouldn't come on. Anyhow, battled through it and all is well!
    Thank you.
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Aprilaire 700 draining water even when blower is off
Hello, if the blower is off and the water keeps flowing most likely the solenoid valve is bad and must be replaced.
Oct 24, 2011 | Aprilaire 700 Humidifier
I installed a new Aprilaire 700 and everything looks normal except there isn't ant water flow, I am not sure if this is the solenoid or transformer problems?
Check if you are getting 24 volts at the transformer, if you are then appy power directly to the solenoid valve from transformer, you should here the solenoid valve click and let water through. If not replace the solenoid valve. If the valve works by giving power directly from transformer the check the wiring, humidistat, and current sensing relay/sail switch.
Jan 10, 2011 | Aprilaire 700 Humidifier
How do you set and or reset the "filter replacement"schedule on the April air #700 model?
The owner's manual reads "After the Water Panel is replaced, turn the Control knob to the “Test/Reset” position until the green “Humidifier ON” light flashes, to reset the Water Panel change timer."
Hope you find this to be very helpful.
Let me know if you have any questions. :-)
Mar 20, 2010 | Aprilaire 700 Humidifier
Aprilaire 700 humidifier does not come on
Make sure the fan unit door (over the water panel) is closed. Push on it to ensure it is fully shut.
Feb 16, 2010 | Aprilaire 700 Humidifier
Loud clicking and banging, A700 doesn`t work
You have a faulty humidistat
Greg Sunsetmech
Dec 13, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 using too much water-------
There is a small oriface that is installed next to the solenoid valve. It sounds like this oriface is missing. It reduces the water flow through the humidifier when it is working properly. You should be able to disassemble the solenoid fittings to check and see if the oriface is in the water line. For a "temporary" fix regulate the water pressure down by closing down on the saddle valve.
Good luck
HVAC Teacher
Feb 25, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 leaks water from bottom of case
Install new water panels yearly. On the new panel make sure that the painted dot on the edge of the panel is on the top when you install it.
Always clean the distribution tray and the frame. Make sure the notch on the edge of the distribution tray faces away from the furnace. Make sure the humidifier was installed level. Keep the drain tube opening clear. Insure there is no blockages in the drain tube.
Good luck
HVAC Teacher
Feb 10, 2009 | Aprilaire 700 Humidifier
Lots of water run-off from Aprilaire 760 Humidifier
HI would check the filter in side might need changing or cleaning clean out wter tray in side, it could be just a blocked filter , hope this helps
Jan 03, 2008 | Aprilaire 700 Humidifier
Water dripping from unit
if the water panel needs to be replaced , this can happen. instead of going through the panel , water will run on the outside of the panel and drip through the seems on the humidifier cover. make sure the plastic hose that goes into the water panel is inserted into the water panel.
Dec 27, 2007 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
218 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
