What is Phillips cdrw error code 41? - Computers & Internet
  • Art Ellison
    Art Ellison Jan 02, 2011
    When and where did you see this error?
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Jan 02, 2011
What is error code 41
Good Afternoon Donna,
I see that you are wondering what an error code 41 is on your Frigidaire washer, model# GLTF2940ES. Error code 41 means the control board thinks the door switch is open. You will want to make sure the door is closed. Reset your appliance by either unplugging it or shutting the power off at your home's circuit breaker. When you restore power select any cycle and start it. If you are still receiving an error code 41, I suggest contacting your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire GLTF2940ES Front Load Washer
What's the actual meaning of DTC codes 41, and 58, for this vehicle?
the meaning of codes 41 and 58 is:
DTC - 41 Ignition control error
DTC - 41 MEM- CAL error
DTC - 41 Cam sensor sinal error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS System error
I hope this is helpful
Feb 18, 2013 | 1992 Buick LeSabre
RCA cdrw 121 recording shuts down at 41 minutes
Depending on the age of the unit the linear sled may have a blockage in the worm gear t that point. Does it play a disc all the way through or does it stop at 41 minutes too. This would be a hint. Make sure you are not recording in a high resolution mode which will cut down on time.
Jan 22, 2013 | RCA CDRW121 2-Disc CD Recorder
Brother all in one mfc-255cw error 41 when trying to print across network
While there are many ways to prevent Brother printer error code "41
Sep 12, 2010 | Computers & Internet
41 device error
i have a problem 41 device error in the toshiba dp80f
Feb 17, 2010 | Toshiba DP80F Printer
Mitsubishi 52525 error code 41
Replace the power board thats what causes the Short error 41
May 30, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a F2-41 code. What does this code mean?
- Impropercartridge (destination error, life cycle error) Identification error model error type error destination error data abnormality Misc error
Apr 15, 2009 | Sharp AR-BC320 All-In-One Led Printer
Driver/Firmware Problen on a Lite on CDRW
Here ya go straight off the Microsoft Knowledge Base. Geek Squad too lazy to research:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Recommended resolution
This problem occurs if you install a driver for a non-Plug and Play device, but Windows cannot find the device. Here are some things that you can try to resolve this problem.
If the Troubleshooting Wizard does not resolve the problem, do one of the following:
  • If the device was removed, uninstall the driver, connect the device, and then click Scan for hardware changes to reinstall the driver.
  • If the hardware was not removed, the driver files might be obsolete. In this case, update the driver from Device Manager. In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
  • If the device is a non-Plug and Play device, you may have to install a newer version of the driver. To install non-Plug and Play devices, use the Add Hardware wizard. Click Start, and then click Run. In the Open box, type hdwwiz.cpl.
4 diamonds pls
Mar 01, 2009 | Gateway 510 X PC Desktop
Radio error code 12
hope this helps is it all cd or just cdrw as some cd players wont play cdrw +or - have fun !
Jan 07, 2009 | 1998 Ford Escort
Computers & Internet Logo
David Payne
David Payne
