Question about Pit SSR 110CC Pro Beginner Bike
I have a 110cc pit bike and when i kick the kicker it does nothing and when i pull the throttle back it clicks what can i do to solve this problem realy appreciated
    Guru:
  • 632 Answers
Could be a range of things only way to really know is to take it apart and look for blockages on fuel inline or damage to piston.
Posted on Jan 02, 2011
SSR 110 bike wont start
ok so if its BRAND NEW take it back to the place you bought it mate its engine is dead there is no compression either that or your sparkplug is not in tight or at all (lol)
Dec 08, 2012 | Pit SSR 110CC Pro Beginner Bike
When i give my pit bike throttle it dos not rive the engen
check to see if the trottle cable is attached to the throttle lever, the piece on the engine
Jun 25, 2012 | Pit SSR 110CC Pro Beginner Bike
2008 110cc pitbike wiring pictures
are you getting a spark?
if not then i would suggest the kill switch has gone o/c put a meter on it on contenunity and it should buzz out when switched
John
Mar 12, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
My pit bike wont start my plug keeps gettin full of prtrol and oil and it wont tick over.
take the carb off clean it out then have a play around with the fuel air mixture,that should fix it.
Mar 16, 2010 | Pit SSR 110CC Pro Beginner Bike
110cc pit bike; The kick start kicker used to
Hello - i don't know whether you have sorted this or not, but ill help you anyway. Well.. First of all to get to the kickstart mechanism, you need to drain the oil. Get an oil tub, or a metal jug, or anything along those lines and place it underneath the engine..
Underneath the engine there is a big bolt which should have a red rubber washer, well.. undo that. The oil will drain out of it, tilt the bike left and right to make sure it's all out.
Now you undo the bolts, holding the clutch cover on, this will reveal the clutch. In the middle of the clutch there is a ring with teeth on it, bend them out and the clutch will just pull off, also there is a circlip so be careful and dont lose it. Now it's time to take the whole engine casing off, just undo all of the bolts, and keep them in order because some are different sizes. There is a large gasket so make sure you dont rip it!
There it is. The spring mechanism, if you want to go further, you will have to take the cylinder off to split the engine to get to the gear box.
Jan 14, 2010 | Pit SSR 110CC Pro Beginner Bike
Flywheel doesn't spin on kick over
Flywheel has a keyway that has been sheared or bolt on shaft is loose.Either way you need to pull the flywheel and inspect it...replace keyway..reinstall retorque...Good Luck to you my friend....Tim
Apr 30, 2009 | Pit SSR 110CC Pro Beginner Bike
My pit bike will not keep it revs
play around with the throttle adjustments
Jan 28, 2009 | Pit SSR 110CC Pro Beginner Bike
I have a pit bike and it splutters alot when i ride it
my pit bike will not keep it revs for a long time so can some one help me it is my first pit bike
Jan 09, 2009 | Pit SSR 110CC Pro Beginner Bike
Pit SSR 110CC Pro Beginner  Bike Logo
182 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
