Question about LG Televison & Video
My tv says i am on 480p and want to be on 1080p
    Problem Solver:
  • 15 Answers
Hahaha SUCKS FOR U lol jk mmmm...which satelite u have
Posted on Jan 02, 2011
I have a sharp TV and an trying to CD an Amazon fire stick. TV keeps responding...incomparable video signal...help
The stick is set to 1080p your sharp tv cannot show 1080p change it to 480p in settings , you will have to use it in another tv than is capable of showing 1080p, then just change it to 480p , then you should be able to use it on the sharp tv. You can then try to change it to 720p if it says the same about the signal leave it for 30 seconds and it will revert back to 480p
Aug 02, 2017 | Sharp Televison & Video
How do i change from 480p to 1080p on my rca remote
You don't. The TV's resolution can't be changed. Only the signal resolution from the source can be altered.
The TV reports the resolution of the incoming signal before it is scaled. If you have a BD player you can see the effect of changing the resolution setting from 480p, to 720p, to 1080i, to 1080p 60, to 1080p 24. The last three (the 1080 resolutions) shouldn't look too different with a Blu-ray apart from movement because the native picture is 1080p 24 and the TV is simply converting it back to 1080p 24 for display.
Sep 07, 2014 | RCA D52W23 52" HDTV CRT TV
1080p tv stays in 480p mode
Resolution is a slave to the source. It sounds as though the source is only outputting 480p. Go through the menu settings of the source device(bluray, cable, satellite box, game system) and set it to output 1080.
Jul 10, 2012 | Toshiba REGZA 46RV530U 46-inch 1080p LCD...
My Toshiba 55HT1U is showing 480p instead of 1080p. Why is it not on 1080p?
It is probably your video source. If you are using component video, some devices only output 480p.
Check the settings of your sources. The TV will display only what the device sends to it.
In most devices under a settings directory there will be settings labeled "Video" or "Resolution" Changing these settings to more appropriate High Definition resolutions should solve your problem.
Mar 17, 2011 | Toshiba 55HT1U LCD TV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
I own an insignia 42"
The TV resolution is set by the video sources, not at the TV, in this case, your Dish network box is the one that is sending out 480p so the TV will display what it is being fed with.
What does Dish TV say aboyt this problem? How about the setup menu on the Dish network box?
Your TV works the same as your PC monitor, except that your monitor does not have a tuner, you adjust the resolution at the PC not at the monitor. 480p in = 480p display.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 31, 2011 | Televison & Video
My new set displays only 480p SD on all my HD channels. Am I missing some settings in the menu's or is something more sinister going on? Any help would be greatful, I'm drowning watching sports!
hi,
u can enjoy full hd 1080p video through only ur tv inputs as 2 component video and 2 HDMI. the tv is seted to receive videos up to the resolution 1080p automatically (need not have any setting). just check the output of ur cable box or BD player, is it outputs full hd. if u are using the tvs internal tuner u will only get 480p.
ok
Dec 20, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Tv is showing 480p and we want it at 1080p on our new Toshiba 40XV648 40-Inch 1080p 120Hz HD LCD TV Cinema Series.
After searching the owners manual I find that there is nothing mentioned about the screen resolution i.e. 480p to 1080p.
This set is capable of your desired resolution and as far as I can tell it auto selects because it senses the input video and decides which is the best setting for that source.
It's important to understand that you need 1080p video to use it at it's full capabilities. It won't give you a 1080p resolution from a VCR or a standard DVD player. You need a DVD player that is capable of producing a 1080p encoded video. Some satellite receivers are capable of that but you need to make sure you know what resolution that you are sending to the television.
Local TV stations won't usually broadcast HD at 1080p. Your best bet is to use a DVD player that is capable of that high resolution for your best picture.
Please note that what it says in the owners manual about "Resolution" has nothing to do with the 480p, 720p or 1080p signals, your set selects that automatically it will start by selecting the 1080p then goes to 720p then 420p it's dependent on the video you send to the set.
Please note the "resolution" function is actually like a "sharpness" control.
Your video input (tuner, VCR, DVD, games and etc.) is likely your problem.
Mar 30, 2010 | Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
I dont know if my lcd tv supports 720i, 1080i, or 1080p
Sorry. It does not. 480i and/or 480p.
http://www.generalmanual.com/Televisions/Sanyo-CLT1554-STEREO-LCD-TV-EDTV-Monitor.htm
Picture Resolution: 1024 x 768 (XGA);NTSC (480i) EDTV (480p)
Dec 24, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Televison & Video Logo
Computer Repairing
Computer Repairing
