Question about Kenmore Washing Machines
I have a kenmore top load washing, I moved it out from the wall to clean behind it, and now when it fills up with water it won't pump out the water and spin. Anyone got any ideas? Thanks!
    President:
  • 3,113 Answers
Push down on lid or lid switch.
Posted on Jan 02, 2011
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Washer won't fill water runs out bottom
either you have a bad drain hose or the drain pump has a bad seal behind the outer case
May 01, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Washer fills with clean water when off. Water drips from top, behind door hinge from spout.
Your washer is filling up to much. The pressure value switch, the hose that connects to the outer tub.
May 06, 2011 | Kenmore 94812 Top Load Stacked Washer /...
My Kenmore top load washing machine is stuck in
sounds like ur pump has gone out totally and the controller is bad cause its not filling the tub or is it if it is and just wont pump it out u have a bad pump
Feb 25, 2010 | Dryers
Cold water filling
There are filter screens where the supply hoses connect to the washer. On some brands there is a screen where the hose connects to the water valve at the wall. The screen is probably full of sediment.
Dec 14, 2008 | Kenmore 24622 Top Load Washer
Kenmore front loader keeps filling water in drum and will not stop
Plug off the wall. Open up behind, you will find a thin tube going from the pump area to the control point. This is the water level tube; untie this tube from above & blow into it, it should be free, if not free remove the blockage, see that it is not twisted, insert carefully. Or replace. This shd fix your water level problem.
Rate if helped pl..................
Jan 12, 2008 | Kenmore 44102 Front Load Washer
Open up behind, after taking off the wall power plug. Check to see it the hose from underneath the tub is loose, tighten. Or replace hose if damaged.
Oct 07, 2007 | Washing Machines
Washer
Does washer spin without any clothes or water, try 'spin' only. If no, then u might have a loose connection to the motor. After u disconnect from the wall socket, see behind to see if all connections are ok. Do not over-load your machine, it could trip a switch which will stall things. Suggestions...
May 01, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
11 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
