Its stuck on last function and will not select another function and we have tried new batterys so out of ideas????
    Sergeant:
    Novelist:
  • 185 Answers
I am assuming you are talking about the thermostat. Take the batteries out of the stat and shut the power off to the furnace and let the thermostat alone for about 10 minutes. You can push a few button on the stat to finish draining the power out of it. If it has a reset button you can push it with a pin or toothpick. Then put the batteries back into it and see what happens..... If that doesn't fix it you will need to replace the Thermostat. Hope this helps.
Posted on Jan 02, 2011
Pro-95 will not scan, when first turned on, unit goes to manual mode with last selected channel. Upon selecting SCAN, unit will switch to SCAN mode, but will not move off the bank of last selected...
If you did the hold down '2' '9' reset, there isn't much more you can do. I have tried pulling out the battery pack and putting in a jumper wire between both battery contacts inside the radio (with no battery) and turn it on and let it sit for 1/2 hour. That's about the last thing to try. Only other goofy thing could be you got 'sticky pop' on the 'manual' button, so the radio thinks you pushed the manual button as soon as you turn it on. Make sure that the rubber isn't stuck around the manual button. You could try a QTip with 70% alcohol around the edge of the MANUAL button, but you also might wipe off some lettering at the same time, so use caution. Good luck and let me know how it goes.
Apr 26, 2017 | Radio Shack Pro-95 Handheld Scanner
Battery is dead and wont start
Make sure the battery is fully charged before trying again. If the battery wont charge get a new one. Once installed use a multimeter to verify that the alternator is charging.
Sep 22, 2012 | 2004 Chevrolet Chevrolet TrailBlazer EXT
Fozen curser - worked yesterday- today switch on curser froze, problem switching computer off. tryed turn on and off still same. taken battery off , it now working not sure if related
The cursor freezes when the system is freezing up for some reason ..and the action was a good one ..The idea is when the system is stuck ..it probably either didn't found a file and will stay that way ..or the actions selected was beyond its resources..or so ..
main action is to turn it off by cutting all power/..this way it is similar with a soft reset and if the operation system is not damaged will boot again in normal way ..(if it shows multiple choises ...select to boot to the last known configuration that worked..and press enter ..
Aug 07, 2011 | Acer Aspire 3050-1733 Notebook
Having taken a photo last night the camera turned itself off but seems to have frozen with the lens stuck out. any suggestions
Well lens errors are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism. Follow the below steps to do a try to correct it -
1. Remove the batteries from the camera, wait a few minutes. Put a fresh (or new) set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
If further you have the same problem - it means there is a gear-motor alignment of the lens which moves in and out with the help of motor (it need some repair). This part is replaceable at an authorized Samsung Service Center.
Good Luck!!
Thanks for using FixYa!!
Aug 01, 2010 | Samsung Digimax D73 Digital Camera
Stuck on blue screen and cant get off wont let the freesat function on ext2 any ideas? was fine last nite !!! cable still works ok tho
are you trying to use satellite? if the screen is blue the t.v. is working it is the sat. box. Try to do a hard reset by holding button for 10 full seconds.
Dec 20, 2009 | Philips Magnavox DVD/VCR Dual Player
HELP 350d still not turning on/screen not working
Hmmm... doesn't sound too good does it? Have you tried another CF card? I know you said it doesn't work even without a card but...
Also one last thing to try is to tkae out both batteries, the main one and the slim watch style backup battery that sits right next to the main one under the cover labelled CR2016. Leave them both out for an hour and see what happens. NOTE this will probably reset your camera to factory defaults and may reset the photo numbering counter back to zero. Worth a try?
Feb 10, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Remote wont work
on the thc60 systems the remote comes with a sliding switch on the right side to select tv, vcr, or audio (the jvc unit). with all due respect, did you ensure this switch was at the right selection?
Nov 25, 2008 | JVC TH-C50 System
Error ##343 and it didn't print anything Orange light below screen has been flashing, screen message "Waste Ink Nearly Full". No idea where waste ink container is kept? Have changed cartridges. Now saying...
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Jun 09, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Windows startup is stuck for 20 minutes
Hi, If system is stuck and will not let you do anything (including power down), remove the AC adapter & the battery. Reinsert batter and apply AC power. On boot before Windows start press F8 and select Safe Mode. In Safe Mode, uninstall any program that you feel may be preventing Windows from starting normally. You can also select Last Known.... and Windows will also start with the last known good configuration. You can also use the Uninstall or the Add/remove Program. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 04, 2007 | Toshiba Portege M400 - Core Solo T1300...
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
