Question about Brother LS-2125 Mechanical Sewing Machine
I cant remember how to wind the bobbin on my brother ls2125 have not used it in years
    Genius:
  • 1,788 Answers
Get a free copy of the manual at www.brother-usa.com under customer support for home sewing and embroidery. It will tell you everything you need to know, save it to your computer and then you can also enlarge the diagrams to see better.
Posted on Jan 03, 2011
Sewing machine hand wheel stops needle when it should be working and vice versa
Hi, the link below is a youtube instruction video for a brother sewing maching, Also there's other brother video's you can click on down the right side of page..... I hope this helps...........CHEERS..
Brother Sewing Machine Instruction Video
Apr 03, 2016 | Brother Sewing Machines
How do I change the bobbin winder on the Brother ls2125 sewing machine please
In the meantime, you can pick up a stand-alone bobbin threader at the local fabric store or online. They cost ~$25. A lot of sewists prefer using the stand-alone because it saves wear & tear on their sewing machine and they can also wind bobbins without interfering with the machine's setup.
May 03, 2015 | Brother Sewing Machines
My bobbin won't wind the tread
Did you remember to put your brother into winding mode?
Dec 02, 2012 | Brother XL-2230 Mechanical Sewing Machine
I have a brother sewing machine..LS2125,,does any one know,,the tension for both,,it was moved,,by a child,,now i can`t remember,,i usually just regular sew,tks,,
try a top tension of 3 to 5,, the bottom shouldn't have to be changed unless the child touched the bobbin,, which is more difficult to do
try these sites for a manual
ebay
sewingpartsonline.com
Brother website
Brother home sewing & embroidery
Support- click on it
Find manuals & documentation--Download the latest product
Select home sewing & embroidery
Select model number & view
Apr 01, 2012 | Brother Sewing Machines
Brother SE-270D sewing machine bobbin won't wind
the rubber ring on the bobbin winder has probably gone bad which would mean replacing it but you can buy a portable bobbin winder called a sidewinder for around 20.00
Jun 16, 2009 | Brother SE-270D Computerized Sewing...
Just wondering how do you set the tension for the bobbin?
Page 21 Of The Owners Manual Download able Here
http://www.brother.ca/en/products/pdf/manuals/LS2125-UG.pdf
Decrease the thread tension by turning the dial
to a lower number. If the result is still not satisfactory,
then adjust the bobbin thread as explained below.
Increase the tension in the bobbin by turning the screw with a small screwdriver in a clockwise direction. However, do not turn the
screw more than one full turn.
Remember to return the screw to its original setting before
starting your next project.
Jan 08, 2009 | Brother LS-2125 Mechanical Sewing Machine
Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Sep 26, 2008 | Brother CS-8150 Computerized Sewing...
Brother sewing machine ls2125
Don't go directly from the thread spool to the bobbin.
You have to go via the thread quide, (near the end of the head at left side) and under the small roller.
Pass your thread to the bobbin turn your thread 3 turns to the right, clockwise,
then pass the end of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Push the thread winder lever to lock the bobbin.
Start winding slowly. If the thread is loading in the down position,
put your finger under the thread between the bobbin and the the thread quide, untill you see that the thread is feeding evenly.
Jun 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
51 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
