I have a Rogers hd 3250 cable box, that shows an error code of br07. A friend of mine works for rogers and said there is a sequence of buttons to push to force it to reboot in to guardian mood. Do you know the sequence of buttons to push?
SOURCE: code for remote / Diamond Vision DVD Player model: DVD807-04
I found the code! It is 0736. The company is now called AudioLogic.
Posted on Dec 30, 2007
SOURCE: Cable Box compatibility.
my cable box want turn on
Posted on Jun 20, 2008
SOURCE: Synergy V remote - TV power on to last channel viewed - what's the code??
Actually, there is a setting in the cable box for this. You hit the settings button on the remote TWICE, then scroll down to Viewer:Power On. Click on what channel (or last channel) you want it to go to when you power on. Hope this helps. I have the 8300 HDC DVR.
Posted on Jan 12, 2009
  • 928 Answers
SOURCE: what is the wap setup for Rogers in Canada?
I found this in the internet, why couldn't you do the same? No IPhone app. works with the Sciphone, sorry. Now try thiese settings: Setting's name: Rogers
Homepage: mymobilehomepage.rogers.com
Session Mode: Permanent
Connection Security: Off
Data bearer: GPRS
GPRS access point: goam.com
IP Address: 208.200.067.150
Auth Type: Normal
Login Type: Automatic
User Name: wapuser1
Password: wap
Posted on Oct 27, 2009
SOURCE: my rogers hd box the
Have you tried a signal booster, i really do think that will help. Your reception can be to do with a few thing's, i.e. Position of your tv, Faulty receiver on your main (outside) aerial, A breakage or fault with the aerial cable coming from outside aerial to tv, or your outside aerial can just simply have a bad signal.
Posted on Oct 14, 2010
When I turn my converter box on it boots then shows 4 green lines. How can I fix it?
Lorie, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Easy Fixes to 5 of the Most Common Rogers TV Issues
3 ways to troubleshoot your Rogers Digital TV Rogers RedboardRogers...
Mar 07, 2016 | Televison & Video
Very pour reception on many channels with the Explorer 3250 HD with rogers cable
Dump the cable company. Get all the free TV you will ever need. Download and install Kodi and enjoy!
Mar 20, 2015 | Televison & Video
Why does this error appear hardware not present?
In order to set the Rogers Yahoo Home page, follow the instructions mentioned below:
Internet Explorer:
  1. Open Internet Explorer.
  2. Go to https://ca.rogers.yahoo.com/
  3. Click the Tools button, and then click Internet options.
  4. Under the General tab, Click Use Current
  5. Click OK.
Mozilla Firefox:
1.Open https://ca.rogers.yahoo.com/
2.Click the icon to the left of the web address, drag it to the Home button, and release.
3.Click Yes to set this as your home page.
Google Chrome:
1.Click the Chrome menu on the browser toolbar.
2.Select Settings.
3.Add the home button to the browser toolbar
4.Homepage button is off by default.
5.On the Settings page, select the "Show Home button" checkbox in the "Appearance" section.
6.Set your homepage
7.When the "Show Home button" checkbox is selected, a web address appears below it. Type in https://ca.rogers.yahoo.com/
there.
GuruAid
Apr 30, 2014 | Computers & Internet
Programe sony rm-vl610 from rogers cable
This is the setup code for Rogers cable box. 0506
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jun 23, 2012 | Sony Televison & Video
I have recently gotten a Sharp AQUOS Quattron (LC52LE810UN). I have a rogers cable box with a RCA input, but the tv doesnt not have an direct RCA input. It has a input for an audio cable with a component...
Your TV is a High-Def TV (HDTV) therefore you need a Rogers cable box and service capable of High-Definition in order to get the HD resolution you paid for with the HDTV. HD video requires HDMI or component video cable connections. Standard RCA AV (yellow, white, red) will not show HD video.
Having said that, you may want to hookup a game or VCR to the TV and therefore you will need to get a cable known as an AV miniplug. It has RCA (3) on one end for the VCR for example and on the other end is a Mini-plug to connect to the HDTV (Sharp). This cable is like the ones used on camcorders such as Sony. Make sure you get a cable with the right ends as depicted in your manual on page 14.
You'll have to Google online for a supplier. Sparco.com had these cables but are out of stock currently.
Jan 17, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I have a Rogers HD cable box and want to control my Soyo HDTV with it. I look in the Rogers manual but could not locate the device code. Can you tell me what it might be?
first you have to know witch remote you have there is a 3 button witch has vcr tv and cbl at the top that one there press tv and select at the same time untill the light flashes 3 times release then enter 9-9-1 the pres the tv button untill the tv turns off if you have the newest 5 button remote you will press tv release press and hold setup untill light flash's 3 times then enter 9-9-1 light will flash once entered then press ch+ sevral times untill your tv turns off once tv turns off stop and press setup and that will lock the code inplace i hope that helps
Nov 24, 2008 | Soyo DYLT032D 32 in. LCD Television
Need codes for electrohome lcd tv so i can program it with my rogers hd box
i'm thinking you want to control your tv with the rogers hd box remote.
here is the link please click on the Remote Control Code-Finder
link on it and find your remote.
http://www.rogershelp.com/DigitalCable-Ontario/category.php?id=YY-24
Apr 15, 2008 | Televison & Video
Blackberry 8700c
You maybe able to request thru cingular if that is your provider to unlock the phone. If it shows cingular it was a cingular phone.
Jan 26, 2008 | RIM BlackBerry 8700c Cellular Phone
Code for remote / Diamond Vision DVD Player model: DVD807-04
Jun 10, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
Televison & Video Logo
340 people viewed this question
Top Televison & Video Experts
Electro Med Services...
