Computers & Internet Logo
Posted on Jul 09, 2008
I just got my first notebook it is a compaq evo n400c with a belkin 802.11b (32 bit cardbus)wi-fi card. i am trying to find out how i can get/have internet access where ever i go. how do i go about setting this up.who do i call, and around how much will it cost initially & monthly?
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Jul 09, 2008
Anonymous
Contributor
Level 1:
Answers
34
Questions
Helped
8123
Points
71
Hi Obadiah,
U can take ur laptop to any of the hotspots and u need to turn on the wireless switch in ur laptop so that u can automatically connect to the wireless internet..i think u r aware about hotspots...
If u want to use internet in ur home..u can buy a wireless router..there are lot of companies providing wireless routers..u can buy Linksys..model no is Wrt54g..this wrt54g is a wireless router where u can connect 4 wired desktops and 20 wireless laptops..its cheaper and best.u need to buy a internet connection to connect this router...I suggest u to go for a cable Internet..Cable internet providers are comcast,shah.go for comcast.Hope this info will be useful for u.for further clarifications revert back as soon as possible
WHAT DO I DO TO MY COMPAQ EVO N400C TO GET IT TO RECOGNIZE A REPLACEMENT MONITOR
It should have no problem ,,connect vga to vag out the back,,of evo,,should work,,also the compaq website is very helpful,,support and driver downloads for everymodel,,goodluck
2helpful
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
I am trying to locate where to insert a memory card on a compaq evo n600c. Not sure if it is even possible?
There is PC Card Slots Two Type II/One Type III PC Card Slots which support both 32-bit CardBus and 16-bit PC Cards
http://h18000.www1.hp.com/products/quickspecs/10886_div/10886_div.HTML
If this is helpful please rate
4helpful
6answers
Upgrading memory on my Compaq Evo N400C notepad
i have the same Compaq Evo N400c its a ram under the keyboard check there to upgrade it i got Compaq Evo N400c 1gb ram
Compaq EVO N400c without wireless capabilities will external wirelss card work?
http://www.everythingusb.com/hardware/index/Linksys_Wireless-G_USB_Network_Adapter.htm
This is just one source. I did a google search for USB wireless adapters. They are used by many users. Generally these units cost the same whether online or at the local Radio Shack, etc. because of shipping.
Evo n400c
Did you charge it for up to 8 hours?
Caring for your Compaq Evo N400c Laptop Battery You can improve the life of your Compaq Evo N400c Laptop Battery by doing the following:
When you first receive your laptop battery charge it fully for at least 6-8 hours and then discharge the battery fully by using your laptop unplugged from the mains until it runs down completely.
Repeat this 3 times to ensure your Compaq Evo N400c Laptop Battery will give you the maximum performance.
If you regularly use your Compaq Evo N400c Laptop on mains power for extended periods, removing the battery from your Laptop during these periods will extend the usable life of your laptop battery.
Evo n400c
yes it is possible
if you have operating system of xp than it will install automatically if its not done
then first you should install the driver. then you can use it.
2answers
COMPAQ EVO N400C WIRELESS CONNECTION PROBLEM
Is the truemobile your using a PCMCIA card you slide into a slot or is it a Mini-PCI card that is inside the laptop?
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
