Question about Toshiba e-STUDIO 205CP Printer
HOW DO I MAKE DOUBLE SIDED COPIES USING E-STUDIO 205
SOURCE: how do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Posted on Dec 22, 2008
007tech
  • 95 Answers
SOURCE: Double sided printing with Toshiba Studio 3510c series
In the middle of the main screen (in copy mode) there is a big button called "simplex 1 to 1" or it may say "duplex". on the next screen you'll see different ways to do duplex copies. if you have a double sided original then select 2 to 2 / if you have 2 single side originals then select 1 to 2. Place originals in the document feeder and press start
Posted on Apr 07, 2009
  • 2692 Answers
SOURCE: Printing double sided with MFC-6490CW printer
Hee is you support website See if they have directions(manual ) to download for instructions. I take it that this printer is designed to print double sided else I can tell you the method that works on all printers.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us〈=en∏=mfc6490cw_all
Posted on Mar 13, 2009
  • 214 Answers
SOURCE: Double-sided copy output
In print dialogue box there will be a setting for long or short edge binding, associated with duplex printing. Find it and try it. Good Luck.
Posted on Apr 28, 2009
xptareq2000
  • 1447 Answers
SOURCE: can the toshiba e-studio 150 print double sided?
yes you can print double side manualy
first time print your lowaer cassate after print another side is your copier right single sheet pass print side
thank you
Tareq
Posted on Aug 28, 2009
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
E-Studio 281c is it possible to scan a double-sided document on this machine? thank you.
Welcome to FixYa!
It cannot do double sided scanning but can do double sided copying.
Thank you for using FixYa!
Jas247
Mar 24, 2011 | Toshiba Office Equipment & Supplies
Can you scan a double sided document?
If you have e-Studio 850 of course.
Put original in RADF or glass
on control panel press copy function
on lcd you will see option simplex (see picture)
press it and in sub menu press option Duplex 2-2
set number of copies and press start
that is all
enjoy
BR
Feb 07, 2011 | Toshiba E-STUDIO 850 Copier
We have 2 Canon ImageRunner 3320N copiers, but they are behaving differently when they are being used as a scanner. On one copier, when scanning a double sided paper it will automatically scan each side....
it is in the copier settings. one is actually set up to automaticly do doublesided copies as a default. while the other one is only set up to do singlesided copies
first while on the main copy screen change the setting how you want the copier setup ..... double sided printing, black and white, or how ever you want your defaults to be set up
then you will need to goto the additional functions button and under copy settings you will need scroll down to the second page.
there you will want to hit the standard setting button then click the store button, then click yes... now it will default to the double sided copies.....
hopefully this will fix the problem if not get back to me
Jun 18, 2010 | Canon ImageRunner 3320N Copier
How to make duplex copies from toshiba e-studio202L
I am going to assume you have a document feeder (ADF) on the copier.
Insert originals into document feeder and press the 1-1 simplex button on the LCD screen. If have single page documents that you want to turn into double sided documents then select 1 - 2 button. If you have double sided originals already and want to make double sided copies then select 2 - 2 button. Then hit the green copy start key...done.
Jan 17, 2010 | Toshiba e-Studio 202L Copier
Apr 07, 2009 | Toshiba Office Equipment & Supplies
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
How do i make double sided copies for my HP 2840
When the printer window pops up, click on preferences then features to enable manual two-sided printing.
Dec 21, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Out of staples
in the menu /control panel choose the single or double sided copies w no staples
Jun 12, 2008 | Toshiba e-Studio 350 Copier
Toshiba e-STUDIO  205CP Printer Logo
104 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
