Question about Toshiba 27A44 27" TV
Upper 1/4 of picture is distorted by tightly spaced horizontal lines. What do you think is causing this?
    Novelist:
  • 128 Answers
This sounds like a vertical fold over.
This happens when the filter capacitors close to the vertical IC have failed or changed value. The are very inexpensive, and relatively easy to replace.
Remove the back panel. Locate the vertical IC. There will be a number of capacitors around it (3-4). I just replace them all. They cost under $1 each, so no testing, just change them.
Posted on Jan 03, 2011
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
I have sound but have a black screen with a horizontal line across it
your picture tube may be malfunctioning -- all of the information for the screen is being squished into that horizontal line. If this is the case, you can buy a new picture tube and install it, but that would be the only fix. the only other thing I can think of that might cause this issue would be if you have a large speaker next to your TX. The magnet from a large speaker can distort the television, but it usually gives you a funny green distortion near the magnet without killing your whole screen so it seems unlikely that this is your problem.
May 26, 2011 | Memorex MT2271 27" TV
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
I get three horizontal lines and picture is distorted on start up. Lasts for about 15 minutes and clears itself up. Any idea of what needs to be repaired?
Hi, How are the lines positioned? are they equally spaced creating four equal sections or are they close to each other?
Jack
Oct 12, 2010 | Toshiba REGZA 46RV530U LCD TV
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
Toshiba 27A44 27" TV Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
