Hi, I am having a little trouble with my sharp adding machine. There are empty spaces. All numbers are not showing. For example if I add 3 + 3+3+1 the answer being 10. The 0 will print but the 1 will not. How do I fix?
    Problem Solver:
  • 7 Answers
First of all if its not printing,check the ink roller,does it have ink and is it sitting well. go on check if there is no small torne papers in the printer these will block the hammers from striking the print wheel. If its not showing those digits at all change the display tube.but check for dry joints on the main board that connects the display tube first and resolder them.
Posted on Jan 03, 2011
My TI-5130 will not add and subtract
It probably uses adding machine logic. Try the following example.
3+
4-
5+
You should get 3, -1, and 4 on the screen, the running total. The tape should show the +3, -4, +5, and finally 4, the numbers that you entered and the total. Think of each entry as adding/subtracting integers on a number line rather than 3+4-5;)
Let me know if you have any questions.
Paul
Feb 04, 2016 | Office Equipment & Supplies
Why does My Samsung VRT front loader leave the soap dispenser full of water at the end of the wash cycle. I have to empty it in order to add detergent for the next wash cycle.
there are 2 components to the soap dispenser, 1 using liquid soap has a little tub that you dispense soap into and 2nd you remove the tub when using powder soap. I assume that you are talking about the little tub is filled with water. How this works is by adding water to the tub the level rises and siphoning empties the little tub. If any water remains it is due to water being added after the little tub has already emptied. That is not a big issue and will happen. Just empty the water or add some water to start the syphon process.
Oct 11, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
I can't get rid of the zero in front of the minus, add, multiply and devide sign. how do i get rid of it?
Are you entering any number before pressing the minus, add, multiply, or divide key? Those operations require two numbers; if you don't supply the first one then the calculator will supply the previous answer, which was zero.
For example, to add 2 and 3, press 2 + 3 = and you'll see 5. Now to add 4 to that, press + and the calculator will automatically supply the 5. Press 4 = and you'll see 9.
Oct 08, 2013 | Sharp el-531x scientific calculator
My calculator will add, but after my total and then I want to subtract, it subtracts by the number I added.
If your calculator is more of an adding machine it works a little bit differently than a calculator. For an example: 10 + 5 - 2 on your machine do the addition of 10 + 5, then to subtract the 2 press 2 then the minus sign to get the total of 13. I hope this is helpful.
Feb 06, 2011 | Canon Office Equipment & Supplies
Hi, My name is Lily Ann I'm having trouble with my decimals numbers. the 100.00 number is not showing. Please help! Example: 123.00 It showing as 23.00
There is a switch above the numbers pad that allows you to select the number of decimal points. slide it over to the setting desired.
It is common for this setting to be unintentionally moved.
Good luck and don't forget to vote.
Oct 12, 2010 | Sharp EL-2630PII Calculator
Need instructions for the game count across by Cadaco
Count Across™ Instructions
OBJECT OF GAME
The first player to place four chips in a row, either vertically, horizontally or diagonally wins the game.
Contents
1 Wooden Tray with Content Holder 1 Clear Plastic Slide with holes
1 Two-sided Number Board
25 Purple chips 25 Green chips 1 pair of dice
Set-Up
Each player selects a set of chips (purple or green). Decide which side of the number board to play, Addition Only (blue side) or Addition & Multiplication (red side). Line up the Number Board underneath the Clear Plastic Slide so that the numbers line up through the holes. The raised tab on the Clear Plastic Slide should be face up. Slide the Number Board and Clear Plastic Slide into the Wooden Tray together. The Number Board should rest underneath the Clear Plastic Slide. Each player rolls the dice once to determine who plays first. The player with the highest roll goes first (Player 1).
Addition Only Play
The Player 1 rolls the dice and adds the two numbers on the dice. Places one of your chips on the Number Board over an empty number space that matches the total of the dice.
Example: A play a rolls a 5 and a 3. 5 + 3 = 8
Player 1 finds an empty number 8 space on the Number Board and places a chip into that slot. Player 1 may choose any open 8 on the number board, but may only place one chip on the board per turn.
Player 2 then rolls the dice and places a chip in a space on the number board that matches the total of the dice. Play continues back and forth until one player gets 4 chips in a row, horizontally, vertically or diagonally. A player can remove an opponent's chip from the board in the following instances:
• If a player rolls doubles, they may remove an opponent's chip if it occupies a space that matches the total of the dice. Example: A player rolls a 4 and a 4. 4 + 4 = 8 and if an opponent has a chip in an 8 space on the Number Board, the player may remove the opponent's chip and replace it with his or her own chip.
• If a player rolls the dice and there are no empty spaces matching the total of the dice, the player may remove an opponent's chip that occupies a number space that matches the roll (if only the player's chips occupy those spaces). Then the play ends.
Addition & Multiplication Play
The rules are identical to the Addition Only play, except on each roll players may choose to either Add or MUltiply the numbers rolled. Example: A player rolls a 5 and a 3. The player may do one of the following:
• Add the dice together (5 + 3 = 8) and place a chip over an empty 8 space on the number board
• Multiply the dice (5 x 3 = 15) and place a chip over an empty 15 space on the number board
Warning! Do not throw out the Content Holder. It serves as a platform for the number board as well as storage for the chips and dice.
Jun 19, 2010 | Cadaco Count Across Game
I lost my decimal point
You need to be in add mode, and have 2 decimal places selected for the result.
To change to add mode, make sure the 'K . A' switch is in the 'A' position. To get 2 decimal places in the answer, move the selector in the 'F 6 3 2 1 0' switch to the '2' position.
You can see the above described at
this Sharp.com page which shows the users manual. The manual shows examples.
Mar 19, 2008 | Sharp EL-1197P Calculator
Trouble adding the phone number for New Contacts.
how to add new contact to address book???
Nov 10, 2007 | Nokia 1100
54 people viewed this question
k24674
jasbo
jasbo
