Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Chainsaw will not shut off using stop, I have to use the choke to shut it off. Husqvarna 455 Rancher
The wire on the stop switch probably came of the terminal. take the top cover off 3 screws ,and the air cleaner. you just replug it.
Posted on Jan 26, 2011
455 rancher runs with chock out 15 second and dies
Try opening the choke half way as soon as it starts then all the way open in a few seconds... It only needs the choke to start and should run fine in less than a minute after idleing with the choke not engaged...
Jun 15, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 revs up and down while giving it thortle
Check the fuel tank vent, ive had 455 and a 450 rancher in for repair that have had the same symptoms. Sometimes it can be the breather pipe that has come off the carb, ive had that happen on a 395xp.
The vents are simple to change and it sorted out the problem on both saws. 1 was simple to spot as it leaked fuel when laying on its side.
Feb 14, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Wher do the two carburator linkages hook up to a husqvarna on a 455 rancher
The throttle wire plasric end sits through the back of the crancase and into the square cut a way into the tank back handle, the hooked wire end drops into the carb throttle spindle on the r/h side of the carb, the blue clip on the spendle then rotated and locks the wire in, the choke pull just pushes into the choke spindle on the l/h side of the carb, it has a bullet style end to stop it popping out again
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Not getting gas to the carb
needle valve could be stuck shut ,gas could be gumed up at carb.
Oct 20, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Compression ratio for husqvarna 455 rancher chainsaw
be careful check the compression on that engine it has a compression release valve on the side of the cylinder the release builds up with carbon and it sticks dropping the compression
Aug 27, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Rancher 455 wont stay running
you need too adjust the high jet ccw (making it richer) do do that takes
a little work cause you need a special tool but I can help you around that if you like. let me know
Jul 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Started 455 rancher after setting for about a month. always used stabil in fuel. started with choke on and then turned off choke once saw was running. the saw seemed to be stuck in high idle and would take...
This sounds like the throttle spindle sticking, or the cable sticking, if you remove the top cover and air filter, then push the throttle spindlefully back to the stop screw with your finger, then try again, the spindle may be a little gummed up.
Mar 18, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 455 rancher that won't run at full throttle unless the choke is on. It runs at half throttle fine.
Clean or replace the fuel filter. Check the fuel lines for decay or other damage. Check the muffler for plugging of the screen. Be sure to run with fresh fuel mix and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Nov 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I am getting fire on my 455 rancher BUT IT WILL NOT START
you need turn off you choke one's its fired up... otherwise it will flood the saw with too much fuel...
Aug 05, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
346 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
