I have a Sanyo PLC-XU07N, bulb is brand new and when turned on standbye light is flashing and that's all it will do.
    Brigadier General:
  • 8,909 Answers
When a Sanyo XU range is powered uop, the first thing that is scanned by the uProcessor are the fans. If one is not turning, because the old lamp exploded and the glass is stuck to the blade, the standby lamp will just flash.
Check all of the fans.
Posted on Jan 02, 2011
  • 1 more comment
  • hawaiian61 Jan 02, 2011
    I have checked the 2 fans and they both are working properly. Is there anything you think could be making the standby stay on? Thanks!!
  • specialistel Jan 03, 2011
    I have had a look at the XU30 service manual which is very similar and when powered up, the periferals are checked first being DVI Board, Input board and temperature sensors. If all hand shakes are successful and the start button is depressed, the fans start and the ballast fires the lamp. It then looks for lamp start, if the ballast fails to start a signal is sent to the uProcessor that halts the system and it returns to standby with the flashing indication to inform the user there is a problem.
    Unfortunatey, I suspect if the fans are OK and not jammed, the ballast unit is most likely the next fault. That must be replaced as it has no serviceable parts.
    Hope that helps you to fault find.
    One thing to check is that the ballast control plug is seated correctly as are the edge connectors connecting the DVI boards and LCD units.
My Sanyo plc xu70 projector lamp is brand new after replacing it still has the same prolem.when I turn it on the power light gets green for seconds then red blinks then it stops..what do you think the...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 17, 2014 | Sanyo Projector Lamp for PLC-XU70
I put a new bulb in a sanyo plc-xu73 projector still no light how do i test the bulb to make sure its not bad
There's no test equipment for DLP lamps.
The only way to test the lamp is with a working projector.
I am a Tech many times, I can tell by a visual inspection.
If you purchased a cheap lamp, or from someone beside a Sanyo dealer then, you may have a bad lamp.
www.aaatvservice.com
Jan 26, 2012 | Sanyo PLC-XU73 Multimedia Projector
Sanyo plc xu115 new bulb wont fire. power light turns green at first but after a few seconds it turns flashing red. the old bulb exploded on this projector.
Could be a burnt capacitor on the circuit board. Replace capacitor if you can determine which one it is. There are only a few.
Apr 20, 2011 | Sanyo PLC-XU115 Projector
My Sanyo PLC XE31 wouldn't switch on, bulb replacemetn lamp was lit. Changed bulb and now it switches on, green light shows, fans run, and then after approx 30 seconds the red light flashes and it switches...
1, the lamp is ok
have a nice day!
Jan 24, 2011 | Sanyo FOR PLC-XE31
Hi i have sanyo xu58 , i cant seem to find a bulb , Will there be any other bulbs that will fit mine?
Hi I have recently purchased Sanyo projector bulbs from avpartsmaster, google them they are based in Bracknell Berks, failing that you can pick them up brand new on ebay.
Good luck.
Ian.
Dec 20, 2010 | Sanyo PLC-XU58 Multimedia Projector
I just replaced the lamp on my Sanyo PLC-XP55 projector and reset the lamp counter but now it won't turn on. When I press the power button, it goes into a cooling mode for 90 seconds and then never turns...
did you get the bulb from sanyo, or from another company that sells aftermarket bulbs? some of those are cheaply made and malfunction shortly after if they work at all. find your reciept, take it back and get a new one.
Jul 22, 2009 | Sanyo PLC-XP55 Multimedia Projector
Sanyo plc sw30 help
i had a sanyo plc sw30 wich had the same problem and it turned out to be the bulb replaced it with new one and this seemed to solve the problem. Theres a few places to get new ones but they are not cheap looking at between £150 to £180 hope this helps
Nov 02, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
219 people viewed this question
k24674
