Question about Element Televison & Video
My son received a Element 42" PDP TV for Christmas. Is there any temp lows or highs that will affect the tv?
  • nancywoodard Jan 02, 2011
    We stored it in a garage with the temp reaching 10 degrees farenheit. We have not turned it on and don't plan on for another week. It is now in the house still in it's box. Have we damaged it by not keeping it above freezing?
  • 10,594 Answers
TV wont affect with room temp, mostly PDP tv equipped with cooling fan/s to maintain internal temp.
Enjoy your tv without any worries.
Thanks.
Posted on Jan 02, 2011
  • Shahid Electronics
    Shahid Electronics Jan 02, 2011
    Only rich humidity could affect tv if its not in its packing. Once you get tv back in living room, let it sit for an hour or so then turn it On just to be remain safe.
    Thanks.
Received a 24" Element Electronics
All electronics after assembly, there is a lite oily glaze that is aplied the prevent any contamination from moisture. Its a bit unplesant, but not harmfull. Also, for an Element, make sure you registure the product so your warrenty will be in affect.Your most likely gonna need it, their a relativly new company.
Mar 06, 2011 | Element Electronics Televison & Video
Philips 42 pf 5592/32s ftv 1,9 -de aa
is the light blinking in a particular pattern?
Jan 31, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
I see 11 flashing groups of about 4 ununiformely-doted lines (black and white) on my screen. Ech group of 4 lines is separated from the next by about the same width of the group (i.e. the screen is divided...
there maybe some problem with the vertical circuits with your tv, if you are still satisfy and tv is viewable then patiencely watch it. however as times goes by using it, if the defect is not corrected it may worsening the vertical circuits problem. scanning vertical trace is the problem of your tv.
Feb 06, 2011 | Pioneer PDP-4271HD 42 in. Plasma...
Pioneer PDP-42A3HD - TV turns itself off...is
Here is the link for the manual - c ould be a remote set up issue or this could be puffed caps in the power supply - have a qualified tech check that out
http://tv.manualsonline.com/search.html?q=PDP-42A3HD&submit.x=49&submit.y=15
Jul 03, 2010 | Pioneer PDP-42A3HD 42 in. Plasma...
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
HOW CAN I GET A BETTER ,SHAPER PICTUER NO MY TV
The sharpness of your picture is dependent on the resolution your TV and device(s) are capable of producing. This TV is capable of showing video in resolutions up to 1080i. 1080i is a good quality of video, so the lack of clarity in your picture is likely being caused by your video source. Basically, the principal of Garbage In, Garbage Out applies here. If your video source is low resolution, even the best TV won't be able to produce a clear picture from it. If you're using VHS and standard definition cable, switch to Blu-Ray and ask your cable provider about high definition tv. Make sure you're using the proper cables (ie., HDMI) as older types such as composite can't support high definition video. Once again, your TV wont polish any poop for you, but play some decent quality video through it and you should notice a world of difference.
Oct 26, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
ESA plasma TV model pdp 4294lv1 does not work
my esa plasma tv model pdp 4294lv1 has sound and i can switch the tv channels, but the color is blurrier
Jul 22, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
HD4208TIII-PDP 42'' Plasma TV
Your TV may not support your HD channel signal. Check with HD DVD & non-HD DVD players to confirm.
Jan 01, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Televison & Video Logo
22 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
