Hello, my monitor (philips 170S) is going in "AGING . . ." when i turn ofg the pc..when its open the monitor keeps switching off and on constantly..none of the front panel buttons works while this happens,
Open the monitor and chek with multimeter all buttons on the small PCB. (Front pannel buttons). On my Philips 170S the seccond button from left to right was defekt. Change the button and enjoy.
Posted on Nov 07, 2011
The monitor setup box and the OSD box pop up all the time making it absolutely impossible to use the monitor as I can see nothing behind these boxes. How can I remove them?
Helo Lorraine , try this , shut off your monitor and wait a while,then take out the power plug and spray contactspray on the on /off and menu and all the other switches under the screen and keep on pushing on the switches a lot of time, then wait a few hours till the spray is dry, then put in the powerplug again and swith the monitor on. Now the monitor is allright and working as it should.
Aug 06, 2013 | Philips Repair Kit, Phillips 170s Lcd...
How do I remove the monitor setup screen which keeps popping up, I can't see anything behind it, it is most frustrating!
Controls are on the MONITOR , not in the Computer .
Set it up once correctly , then EXIT . No more problem..........
Aug 06, 2013 | Philips 170s Monitors 17inchs white
Philips 170s menu keeps on popping up
Sounds like a bad controller board. Board-level repair on a monitor controller board is quite difficult and bound to fail, for a number of reasons. You can look at the part number on the controller and try to locate a replacement online. Otherwise, the switch for the menu might be bad.
Mar 30, 2013 | Philips 170S7FS 17" LCD Monitor
Philips 170s LCD Backlight turns on only 1 sec and than the backlight off. The indicator lamps still green.... anyone can help me? thanks
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 08, 2010 | Philips 170S5FB 17" LCD Monitor
My philips lcd monitor in side dim please healps model philips 170s
It sounds like the backlight has gone out. Replace the monitor.
Feb 06, 2010 | Philips 170S4FB 17" LCD Monitor
Philips 170S keeps turning on and off
Yes it is simple. If you have the expertise you'll find 5 capacitors on the power board are bulging. These are bad and need to be replaced. Most of the time your nearest Radio Shack will have the correct values. If you're comfortable opening up the monitor then you'll need to take it to a pro.
Jun 04, 2009 | Philips 170S5FB 17" LCD Monitor
My monitor is upside down
my phillips monitor 170s has the brightness screen and the OSD controls locked/unlock how do I fix this
Jun 03, 2008 | Philips 170S4FG 17" LCD Monitor
Computers & Internet Logo
1,404 people viewed this question
David Payne
David Payne
