Question about Car Audio & Video
Radio pin code for barina 1994 - Car Audio & Video
  • 4,885 Answers
Post the radio make+model plus all the letters+numbers on any labels , barcodes or stamped in the metal.
For further information
CLICK HERE
Posted on Jan 02, 2011
I have a 2009 holden barina 4 door sedan and I require the 4 digit pin code for radio please
Hi Pam I would be quite suprised if anyone would be able to help you with a pin code for your radio on this site for security reasons.
My advise would be to search through all the paper work and hand books you received with the car first and see if you can find the code. Then either to see a specalist in car radios who might be able to unlock your radio or Take it to a Dealer with your rego paper as proof of ownership. They will do there best to help and should be able to get the code for your radio. They may have to remove the radio to obtain serial numbers etc.
Oct 04, 2017 | Holden Cars & Trucks
My daughter bought a second hand Barina and the battery died. Now she does not have the code to reset her car stereo. How does she reset the code?
you need to take the radio out and get the numbers off of the back call the dealer with them and they can give you the code.
Sep 22, 2014 | 2006 Holden Barina
Lost radio code
YOU WILL NEED TO GET TOO A WORK SHOP THAT HAS A SCAN TOOL AS SOME MODELS ALOW YOU TO GET THE CODE OUT THE BCM FAILING THIS YOU WILL NEED TO TAKE OUT THE RADIO GET THE SERIAL NUMBER DATA BAR CODE ETC SEND IT TO THE DEALER SHIP AND THEY CAN GET IT OFF THE HOLDEN DEALERSHIP WEBSIGHT
Jan 21, 2013 | 2006 Holden Barina
Instructions how to insert unlock code for radio Holden Barina. I have the code just not sure how to input it
If your radio is made by Blaupunkt ( As most Barina radios are ) then here are your instructions.
If yours is a different make then please post a new question quoting the radio MAKE & MODEL
HOW TO ENTER A BLAUPUNKT RADIO CODE
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Jan 16, 2011 | Blaupunkt Car Audio & Video
I have a 1994 holden barina & need the security code for the cassette/radio. Thanks
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Oct 01, 2009 | Audiovox Car Audio & Video
Holden barina 1994 manual gearbox linkage problem
had the same sorta problem with my one, i replaced the las part of the linkages thats connecte to the gearbox, that helped with it. also check to see if the blots holding ur gear stick in place are tight
Sep 01, 2009 | 1994 Honda Civic
Security code for the radio in a 1997 holden barina
You will have to phone GMH in Melbourne for the code
Mar 20, 2008 | Audio Players & Recorders
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
