Question about Garden
I have a Ryobi CD125 battery charger for a drill. It was not charging and I replaced the fuse. The lights on the charger came on briefly after I plugged in the battery but then almost immediately went out, making me believe I blew another fuse. What should I do next?
Your battery is probably dead.
Posted on Aug 04, 2011
Ryobi charger bcl1418
Usually this is indicative of a bad battery. First try a good battery in the tool to make sure it is OK. If the tool is OK, you need to try charging the good battery in the charger to see if the charger is working properly. If the charger is OK, replace the bad battery. Some batteries will show fully charged on the charger but will not supply the power to the tool.
Oct 08, 2012 | Ryobi Drills
Yellow and green light are on but wont charge battery?
If both lights are on and both are flashing the charger is reading the battery as defective and the charger won't charge the battery. If the Red light (yellow if plastic is faded) is on and the green is flashing the charger is trying to charge the battery. If the battery won't charge replace it.
Dec 21, 2010 | Ryobi Multi-Volt Battery Charger
When i place a 18v battery which is dead on the charger both red and green lights come on and stay on. This is happening with both batteries. and neither holds a good charge. What is the problem? It is...
In some model the FUSE got burn.But if this is not your case one or both,batts and charger are burn.Try first to change the batt, then if this not work, change the charger.
Nov 08, 2010 | Ryobi Multi-Volt Battery Charger
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Nov 13, 2009 | Ryobi Multi-Volt Battery Charger
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
Green and yellow light on charger; Battery does not charge.
check the terminals or wirings if it has detached,or its fuse,if after doing it you find out that your fuse is good,then your battery battery needs to be replaced
Oct 22, 2009 | Drills
When batteries are pluged in lights do not light up to show charge
Then unfortunatly your battery charger is faulty and has to be replaced. If the unit is under warranty a Ryobi service center will be able to supply on free of charge.
Apr 15, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi charging stand BCSC12C does not charge battery
i have a manul that you can fix all your batterys ,very easy email me i will send you the file cheers at pfcatering@optusnet.com.au
Feb 13, 2009 | Ryobi Multi-Volt Battery Charger
Charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Garden Logo
291 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
