Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
92 lincoln contiental brake problem - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
    Problem Solver:
  • 15 Answers
Alright, maybe your brakes are broken
Posted on Jul 13, 2008
Motor temp sensor on 97 Lincoln contiental
It is usually in one of the cylinder heads or somewhere near the thermostat housing. Look for a 1 or 2 wire connector with a brass nut below it.
Jun 25, 2014 | 1997 Lincoln Continental
Code 10 for air ride suspention on a 1994 lincoln contiental
Not sure what a code 10 is, but I had to have both of my rear air shocks air bags replaced on 2000 town car, and soon after the motor that controls them it was not a fix by any mean not sure if that helps you any but I hope so
Jun 03, 2012 | 1994 Lincoln Continental
Whetes the brake light fuse on 92 lincoln
The brake light fuse for this 1992 Lincoln continental is located in the fuse box located on the driver side of the dash.You will need to look under the dash on driver side. i have enclosed a picture diagram of the fuse box and i have circled the brake light fuse.This fuse is in slot location # 1 and uses a 15 amp fuse. hope this is helpful. any other problems let me know, good day.4_29_2012_9_00_43_pm.gif
Apr 29, 2012 | 1992 Lincoln Continental
Where is the computer located 96 Lincoln Contiental
Hi, the computer is located on the engine side of the firewall. There may be a bar that goes from the tops of the strut towers. If so, remove bar and the computer is where a large bundle of wires goes into firewall.
Take care
Jul 31, 2010 | 1996 Lincoln Continental
Where is the low pressure Freon port on a 2001 Lincoln Continental?
Infront of the firw wall on the passenger side sticking strait up,, usually with a black cap. the high pressure is located under the black plastic fancy lincoln engine cover infront of the radiator.
on 1998-2002 lincoln contientals
Jun 24, 2010 | 1996 Lincoln Town Car
Where do i spray quick start fliud in a 96 lincoln contiental
Do not spray starting fluid in your engine!!!!!!!! You can and will do damage to your engine. Not Recommended!!!!!!
Dec 05, 2009 | 1996 Lincoln Continental
92 Lincon rear brakes locked up
You will probably need to replace the brake lines. You should do this soon as the constant pressure will cause the rotor to heat warp. You should replace both brake lines to prevent future problems.
Jun 21, 2009 | 1992 Lincoln Continental
Car alarm
try unplugging the connector at the trunk lock cylinder
Jun 15, 2009 | 1998 Lincoln Continental
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal De
