Question about Kenmore Elite HE4 Electric Dryer
My dryer internal light is on, but the font panel and start buttons have no lights, nor will it start
    Problem Solver:
  • 15 Answers
Rfyht
Posted on Jan 02, 2011
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
How to change epson lx 300 font size
Unfortunatelly you can not change the fontsize of the printer, but you can change the font.
To do this hold Pause button for 3 seconds, then push Font button. Two lights will light on and then off and will show you the current settings of the font. To change the font just click repeatedly the font button untill you reach the desired font following the combinations of light on the table below.
The fontsize is controled by the software you use.
Oct 06, 2011 | Epson LX-300 Matrix Printer
The dryer is plugged in, interior light turns on, panel lights on, thing keeps madly beeping but NOT ONE BUTTON works ... not the off button, not the start button, not the temperature button... the entire...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 14, 2011 | Amana NDG6800AWW Gas Dryer
Control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Aug 11, 2009 | Siemens WT79020EU Electric Dryer
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
I have a Maytag Neptune MDE4000AYW Dryer. The internal light is on but the control panel will not start the dryer. The breaker did not trip, i have full electricity to the dryer. My settings work but...
This is your complaint;
"I have a Maytag Neptune MDE4000AYW Dryer. The internal light is on but the control panel will not start the dryer. The breaker did not trip, i have full electricity to the dryer. My settings work but will not preform when i press the start button. Is this an internal electrical problem? Can i fix this myself?"
Thank you for providing a valid make and model number!
Tip: A volt-ohm meter is a valuable tool for diagnosing problems.
My Solution:
!. Sometimes a breaker will only trip 1 side of the 2 sided breaker. Reset the breaker by flipping it off then back on to remove any doubt!
Note: This is not 100% positive, as a breaker can fail on 1/2 the sides, so you will need a meter to test voltage, if you have ruled all else out.
2. Sometimes a thermal fuse in the dryer will open due to a venting issue. The fuse is mounted on the blower housing
or on the element tube. See links for part diagram: http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516650&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1660&PPStack=1
See this link for diassembly procedures:
http://www.repairclinic.com/0100_18.asp
Inspect your vent thouroughly for obstructions. Also, inspect your lint filter if you use fabric sheets, by holding the filter flat under running water. If the water beads up and does not strain through the filter screen, replace the filter and avoid using fabric sheets.
3. The door switch may have failed, see link for part diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46718, See item no.6.
4.Wiring: The wiring at the dryer terminal block may have burned up. See link for diagram:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516193&PPStack=1
5. Push to start switch failure. See link below:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1033496&PPStack=1
In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 16, 2008 | Dryers
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
42 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
