Question about Kenmore 72002 / 72004 Kitchen Range
Oven does not heat, setting oven temp the cleaner latch lights up
    Sergeant:
    Novelist:
  • 185 Answers
Does the Broiler Work? Make sure you have 220 Volts to the Oven. Take the 220 breaker and push if all the way off and then snap it back to the On position. If the Broiler works and the bottom elements doesn't get hot you have a element out. They are not to hard to change. Shut power off to oven and take the screw out at the back in the middle of the element and the elements pulls out and then unhook the wires and replace with a new one. If you have a volt meter you can OHM out the heating element. You should get a buzzing noise if it is good. The other part of the equation is the temperature control that could be bad so use your Volt Meter to do some minor checks before you start replacing parts. Hope this Helps!
Posted on Jan 02, 2011
What temp & time to clean self cleaning oven
a self cleaning oven will have a setting that is specific for this. It will heat up to around 550f for 4-6 hours and will apply a safety latch to prevent the door from being opened. You cannot achieve this type of cleaning without going into the "self-scleaning
" mode as the temps are higher that what is available with your normal settings
Nov 27, 2011 | Cars & Trucks
We have a 24" wall
The problem is due to the door latch and specially one of the two micro switches is not contact properly that is why when you cracked little the oven can work little better. So all you need is check the latch at the back and if nessesary replace the latch
Also you can find a new latch at the links and here
Sep 19, 2011 | Kenmore Ovens
I have a 1960s GE P7 oven that will not heat. How can I test the WB 22x53 switch? Could it be the latch release switch or the oven temp rheostat? The oven makes a humming noise when the dial is turned...
you can test any switch or relay or capacitors on the control board with an ohmmeter in the ohm setting. If low or no resistance, then it is bad. You can get any parts and manual at repairclinic.com or appliance411.com
Oct 14, 2009 | Ovens
Auto oven cleaner
I removed the two screws that hold the warning plate that has the latch coming through it. This allows the oven lock lever and latch to move around. you will see the shiny base of bracket that holds the lever and latch mechanism. I took a plain butter knife and pushed back the insulation to see the switch. I then put the butter knife against the switch and rapped it fairly hard with the screwdriver handle 3 or 4 times. Put the plate back and screws back. Turned on the breaker and was good as new.
Tools needed.. butter knife and nutdriver to fit screws.
Jul 10, 2008 | Kitchen Ranges
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Self Clean won't start - Amana ACS3350AS Gas Kitchen Range
Our door on this oven is coming apart, so the oven door never truly closes.  When you set the self clean cycle, push the door shut until it locks... at least this has worked for me.  But I think all your problems, which are similar to mine, result from the oven door not truly closing... heat escapes, so the temp is not right and takes forever to heat up.  The heat melts the control panel, causing other problems.  In fact, our door is starting to fall open... a bit dangerous.
May 06, 2008 | Amana ACS3350AS Gas Kitchen Range
I have a hotpoint RGB745 oven temp problem
sounds like abad oven ignitor issue, repalce hte ignitor nad it should light everytime
Mar 09, 2008 | Hotpoint RGB745 Gas Kitchen Range
1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
Feb 18, 2008 | Ovens
Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
May 05, 2007 | Smeg S351X/5 Electric Single Oven
Kenmore 72002 / 72004 Kitchen Range Logo
119 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
