Question about Technics SA-AX910 Receiver
My technics sagx190 keeps giving me a power overload and tells me to turn it off. Any ideas?
Kimi
  • 277 Answers
SOURCE: Overload on Technics SA-AX710 Receiver
first of all, check all the capacitors. Other than that, it needs a repair guy to have a poke about inside it with a screwdriver. Has anything happened to it lately that could have upset it a little bit? such as a powercut or had anything done to the plug? (e.g. change of fuse, and put in one that was a different rating) And is it plugged into a surge protection socket, or a plain old fashioned electrical socket?
Posted on Nov 22, 2005
freetek
  • 5568 Answers
SOURCE: Overload on Technics SA DA10
This is an old message so you may not be interested any more.
There are a couple of possibilities; the high power of this unit seems to fry speakers fairly often and although they mostly fail 'open,' they can overheat causing the voice coil to lose its insultation and cause a short instead.
This may also be caused by the failure of one or more output modules causing the power supply to limit and give you the overload indication.
If an output module has failed and the unit is not limiting current, it may destroy speakers too.
Some knowledge and a decent meter would reveal the nature of the failure pretty quickly but describing the steps necessary to troubleshoot this is a little beyond the scope of this forum.
Posted on Apr 23, 2008
tech48
  • 624 Answers
SOURCE: my technics keep telling me
There are only 2 things you can do as the end user.
1. is to disconnect the speakers and see if it turns on without the overload error. If it does, you may just have a bad speaker or speaker wires that are shorted together.
2. Unplug the unit from the wall and wait about 2 or 3 hours before plugging it back in. This will reset the microprocessor and if the micro has any minor software glitches, it will clear them.
The most likely problem is that one of the output amp IC's is shorted and it is going into protect mode.
Another possibility is that the solder connections on the amp board are bad. These Technics receivers are very well known for that.
If the first 2 suggestions do not help, you should take it in to a repair center to have it looked at by a professional unless you are have some very good soldering skills, and have a multimeter to check some voltages.
I hope this helps,
Posted on Jun 22, 2008
  • 336 Answers
SOURCE: receiver says power overload, turn system off
It probably needs soldering of the voltage regulators and/or output IC.
I think that model has an access panel on the bottom (it may need to be cut out then rotated and screwed back on when done).
If it doesn't have the panel the main circuit board needs to be taken out to access them.
The regulators and output IC are mounted on the main heat sink. a little soldering and it should be good as new.
Posted on Feb 17, 2009
  • 4 Answers
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Posted on Apr 23, 2009
Technics stereo Integrated Amplifier SU-G75 powers up few seconds then overload light appears and a clickng noise coming out of metal boxq with tag FP-3 M V RTP1P5C015 on it iis it supposed nto make c
If the receiver works at low volume, but goes into OVERLOAD and shuts down at higher volume, it means you are player the unit too long and too loud. Try yo keep the volume down to a reasonable volume.
Nov 15, 2014 | Audio Players & Recorders
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
I have no sound and it reads overload and tells me to turn off power. what do i need to do?
Hi
I have the same problem and a common problem with this model is :
"Technics models are sort of notorious for bad solder connections, especially
at the output IC's and regulator transistors. "
I hope this helps you
Sep 08, 2009 | Technics SA-AX540 Receiver
Tecnics SU-G95 stereo overloaded
Power down,disconnect the speakers and power back up. If it still say's overload, it needs to go to service. If not, check your wires, connections, and speakers one by one to hunt down the problem and correct. Hope this helps
May 25, 2009 | Technics SUV500 2-Channel Amplifier
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Dec 21, 2008 | Audio Players & Recorders
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Feb 23, 2008 | Technics SA-DA10 Receiver
Tricity bendix keeps turning off !!
assuming you still have power to machine, it could be that the main circulating pump has a thermal overload in it which is tripping off. can you give me more detail?
Apr 23, 2007 | Tricity Bendix 18 in. DH090 Free-standing...
Nov 22, 2005 | Technics SA-AX710
128 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
