Question about Samsung RS2630SH Side by Side Refrigerator
My Samsung fridge stopped dispensing water. I changed the filter and checked the fridge temp as suggested in the manual but still nothing. Any suggestions?
    Genius:
  • 1,456 Answers
Hello
First you need to see if water is getting to the door.You need to determine if the water is blocking in the freezer door or in the fridge chiller bottle (the bottle will be behind the evaporator cover in the bottom of the fridge). You have to track the water line and disconnect it from the bottom of the door.
There should be a connector to disconnect the pipe going into the door.The normal type of coupling is the one where you press the coloured ring on the end of the coupling allowing the pipe to be taken out.
Disconnect the pipe and try the water dispenser, if water comes out of the pipe but not from the dispenser when it's connected this would confirm the pipe in the door is freezing.To solve this,the door will have to be replace because the insulator is no longer able to stop the pipe from freezing up.
If still no water trace your lines back into the fridge compartment and make sure it is not kinked or even frozen,In this case the best option will be to call Samsung because they do have a 5 year warranty that covers frozen fridge compartments..
Posted on Jan 03, 2011
No Water going in to the fridge
Hi Norm,
Most fridges don't need a motor to run in order to dispense water. A simple on / off solenoid on the water line (same for the ice maker) that makes a click when changing from off to on and on to off is usually all anyone hears (the ice maker makes rumbling sounds and you can hear ice falling into the bin - too).
Check for ice. If it has a maker and it is making ice, the problem could be a defective water dispenser switch, solenoid or other circuit component or wire. If no ice, I'd suspect a filter or water supply issue.
Make sure the filter is fully inserted and twisted into place. Many filters have marks to align when 1) inserting and 2) to let you know when it is installed correctly. When sure it is installed correctly - try to dispense water again. Many fridges will dispense water without a filter. Check your manual before trying this though! If not working still, remove the filter and try to dispense water. If you're able to dispense water, the problem is either the installation of the filter or the filter itself. Try to re-install it correctly. Try to dispense water again.
If it still doesn't work - call the plumber back and ask why there's no water. Or - try this yourself:
Locate the point of attachment to the domestic water supply that the plumber used. There should be a valve to turn the water on and off. If off, turn ON. Try to dispense water again.
If that doesn't work - check to see if the fridge has pinched, kinked or crushed the water supply line. You may need to move the fridge forward to gain access to the water line and connection point on the fridge. Repair or replace the line as needed and route in such a way that moving the fridge in or out will not cause it to damage the line again.
Nov 06, 2015 | Refrigerators
Refrigerator temperature shows 60 degrees but waterline is freezing
yes thermastat maybe bad check sencer for temp it maybe bad
Aug 29, 2014 | Refrigerators
Water dispenser beep-beep
I am wondering about the hose you shoved in and the leak stopped. Is the hose you pushed in buckled where it hooks on or is there a buckled spot where the water comes out of the fridge. Just a guess.
Mar 03, 2017 | Hotpoint HSS25GFP Side by Side...
Water dispenser is not working
check your water filter (change it) or a water valve in the back of the fridge. make sure it has power on it when the water lever is pushed. if there is power there then most likely its the valve.
Oct 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung side-by-side fridge freezer model RS21DCSV. Freezer is fine. Temperature keeps changing in fridge varying from 5-14 degrees and water has stopped coming out of dispenser. Have checked and...
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Sep 17, 2009 | Samsung RS2556 Side by Side Refrigerator
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
I have a rs21dcns fridge freezer. i'm having trouble getting water from the water dispenser and also having trouble setting the temperature control for my fridge.
The water stops flowing from the dispenser when the external water filter needs changing, stick a new filter and it should start working again, it sometimes takes a few minutes to clear the air after the filter change.
Sep 07, 2008 | Samsung Refrigerators
WATER DISPENSER,
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE!
Aug 02, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
161 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
