Question about Nitro BMW-628F Car Monitor
I am hooking up power to my Nitro bmwx632f and only the lights come on. The monitor does not. I am using the 18ga wires that are hooked up to the light circuit board. Yellow, red, and black. Is there supposed to be another wire for power to the monitor?
2 Suggested Answers
  • 47 Answers
SOURCE: screen wont turn on
YES YOU NEED A VIDEO SOURCE
Posted on May 13, 2008
No power to monitor
check your remote turn on wire that goes between your neg. post and pos. post good should be a 12v wire that hooks to cd player for a turn on and off applcation if you wire direct the amp will not turn off and drain your batter dead or tuggle if you like
May 03, 2014 | Nitro BMW-482 Car Audio Amplifier
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
I NEED YO KNOW HOW TO HOOK UP A MICRA FARAD 500K
When I used to do this, I would run the power wire from the battery to the Capacitor and then run power wires to said amp. For the crossover, just run an 16 or 18ga wire to one of the Amps power input instead of running it to the cap if its easier. Not sure what Crossover you have, So check the manual for the correct wire size!
Nov 21, 2011 | Audio Players & Recorders
Nitro 483 amp where do you hook up the power it has a gnd rmt and +12v what hooks up where
Fused 12 volt power wire from the battery connects to +12V at the amp. Chassis ground wire connects to gnd at the amp. Switched 12 volt power wire (accessory) (remote turn on from after market radio) connects to rmt at the amp.
Jan 18, 2011 | Nitro BMW-483 Car Amp
I've hooked up the back up camera to the cameras input and connected the power wire to the back up lights. I'm getting power, but I don't see an option for the camera in the menu nor does the camera come...
i don't know exactly what system you are using
from what you stated your saying the monitor is powering up when put car into reverse
but the camera is not coming on
what this tells me is either the camera it self not getting power or ground
u hooked up the video wire between monitor
the camera needs to get power some how it might be the wire that hooks into monitor but i don't think so usually that just the video wire (but depends on system)
i assuming there is one or two more wires on the camera itself that needs hooked up
a power wire
and a ground wire if there no ground wire then frame where camera is mounted to on car needs to be cleaned of all rust and paint
I assumed allot if this don't help you at all please let me Make and Model # of your camera system and i try and help you more
Nov 16, 2010 | Car Audio & Video
How or where do I hook up the green wire (the one going to the reverse whatever),,,,,..... I would like to hook it up so it only comes on when the car is in reverse and becomes a mirror all other...
I added some extra line and hooked it up to my trailer plugs' light green wire. I also connected it to the tail light solid green wire. Both produced current the same way. Still blue sreen with no signal...but I am sure this s where to plug them.
Oct 19, 2010 | Pyle PLCM7200 Car Monitor
I have this amp and i have every thing hooked up. the blue lights on the side comes on bright, but the green power light dose not comes on can someone help with this promble
does it have a diagonstic light ? sub/ spk wires clear and not touching eachother? battery ok? check ground abd turn inon wire to amo w/ test light for "switched" turn on power from head unit
Oct 29, 2009 | Nitro BMW-481 Car Audio Amplifier
How do I hook up a Nitro capacitor?
the cap will connect "between" the main power/gound leads and the amp. If your amp is currently hooked disconnect the power (be sure to disconnect from battery first) and ground leads from amp. Place ring terminals on both leads (red + black - ) and connect to the appropriate terminals on the cap. Then place another wire from the appropriate terminals on the cap to the power connections on the amp.
Oct 28, 2009 | Car Audio & Video
Red protection light
If the amp is going into protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Sep 12, 2008 | Nitro BMW-482 Car Audio Amplifier
Screen wont turn on
Apr 19, 2008 | Nitro BMW-628F Car Monitor
Car Audio & Video Logo
32 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Michael Kovalik III
Michael Kovalik III
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
