Keeps dripping hot water from around the valves at the bottom of unit
  • david_durnin Jan 02, 2011
    continuos dripping leavin garden sodden
  • david_durnin Jan 08, 2011
    tightened nut but made it worse
  • 43,501 Answers
Check at the base of the stem for the handles, where the stem comes out of the valve body...there should be a hex nut right there...
Take a wrench and tighten the nut down... this will stop the dripping from the valve...
heatman101
Posted on Jan 04, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Jan 09, 2011
    You can repack the valve by loosening the nut and the using teflon thread pipe dope to seal it... but that is a tricky operation and the thread can only be obtained at a plumbing supply house....
    You may be better off just replacing the valve...
    heatman101
Non return isolating valve dripping water tinuously
you have trash in the valve .shut it down take the valve apart clean it . also maintenance on this unit is needed.seal can be bad also. hope it helps.send pictures of the unit and age and model serial number.
Apr 06, 2014 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water dripping from bosch water wizard 13b unit
you can rebuild the flow control valve to prevent this.there is also a new flow control valve that has supersceded some of the older ones.
Mar 15, 2013 | Bosch & Tankless LP Hot Water Heater
I have a GE Profile Water Heater Model #SE40M12AA01.
I recommend safety changes to prevent ruptured water heater and assorted leaks.
135 degree hot water.
Maybe replace TP valve if it is dripping.
Drip pan under water heater with 3/4" drain line to outside.
Expansion tank on incoming cold water line to absorb pressure build-up, and prolong life of tank and plumbing.
Here's why:
1) Yes you can have scalding hot water.
2) I recommend 135 degrees since that will burn the evil right out of ya. And generally kill clothes washing bacteria.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
3) 150 is dangerous and can seriously burn skin in 1.5 seconds. Not safe around children and elderly.
4) Temperature settings on electric water heater are approximate, since thermostats are calibrated approximately, and read temperature through tank wall.
5) Also if you want to increase amount of hot water for high-consumption household, then setting tank temperature upward is one solution since more cold water is mixed with hot, so amount of hot inside tank goes further.
6) High temperature can cause TP valve to release water.
TP valve is pressure-temperature safety valve. Do NOT cap off.
Rating should be 125 psi and 180 degrees ... but all things water heater are approximate, and TP valves need replacement now and then.
It is not recommended by water heater manufactures to use 150 psi TP valve when water heater came with 125 psi. Rating shows in small print on end of TP. New TP valves sold at local hardware. Let tank cool before installing new one.
7) Higher temperature and high pressure can rupture tank.
Pressure over 80 psi shortens life of water heaters and plumbing fixtures. Put BTG100 pressure gauge on water heater drain valve to check pressure.
8) You need a drip pan with 3/4" drain line to outdoors, or to drain vent line, to prevent flood caused by ruptured water heater.
Turn water heater off when going on vacation.
Inspect water heater each 6 months.
Drip pan available at local home center or hardware:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#drip
9) Heated water expands and puts pressure on tank and pipes.
Water does not compress... so when water gets hotter it expands against tank wall and against pipes.
Especially in closed system (check valve present) when system is without expansion tank.
Expansion tank is installed on incoming cold water line.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#expansion
Oct 31, 2012 | Water Heaters
I have an MAV7600 Maytag washer the hot water fill valve drip after the cycle complates
if the washer keeps taking water and even when the washer is on the off position.
The problem could be a bad water valve.
Mar 15, 2012 | Maytag MAV7600 Top Load Washer
Our machine keeps dripping water once load is finished. We have turned off water and checked hoses as well as the water inlet valve. Everything looks fine. It is only when the hot water is on, I shut...
I would replace the inlet valves. Even though the issue is only a drip now, the failing hot water inlet will drip enough water to overflow and flood your floor if left unattended. The failure code you see is because the washer senses the water connections. It is telling you that there's no hot water available. Replace the valve- soon.
Good luck.
Jan 18, 2011 | KitchenAid KHWS02R Front Load Washer
Pop off valve dripping Rheem 50 gal electric valve at bottom
If you are reffering to the drain valve at the bottom of the hot water tank. It may be leaking due to the O ring being cracked or worn out. You can either drain the tank and replace the valve or you can buy a hosebib brass cap and thread it on the existing valve. There is no cause for alarm when doing this as this valve is just to drain the tank when replacing your hot water heater
Feb 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water in ice maker drips
The cause of the constant drip is the inlet valve. Since the ice-maker water doesn`t travel through the filter but directly to the ice-maker, the valve must be faulty to allow water to travel through the valve when it`s not energized.
The valve part number most common for your type of fridge (manufactured by Whirlpool) is W10247725 and retail`s around $25-$30US.
**If you decide to service this on your own remember to unplug the unit and shut off the water to the unit.**
Hope that help`s. If so please take a second to rate the solution I provided for you here at fixya.
Good luck.
macmarkus :)
Dec 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water keeps dripping after machine is turned off.
turn hot water tap off if it still drips replace cold water inlet valve if it stops replace hot water valve
Aug 14, 2009 | Maytag PAV2300 Top Load Washer
Ice maker dripping water even in stop position (bar up) and keeps supplying water to device. water dripping from the bottom of the housing unit at a steady rate.
unplug ice maker if you still have water coming in fill valve is stuck on back on the bottom if not more than likly icemaker bad
Jun 26, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
