Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
The kill switch appears to be working incorrectly. If the brake or cruise control is on the tractor engine runs fine. However, while sitting in the seat, in the on position, engine running, as soon as the brake is disengaged the engine dies. Help?
  • 927 Answers
If the seat safety switch is not working, disengaging the brake or engaging the blades would cause the engine to stop.
Posted on Jan 03, 2011
Engine runs fine if disengage parking brake or engage mower engine will quit
Hi Thomas:
These machines have enough safety switches to drive us crazy.
The engine will run WITHOUT someone sitting in the operator seat ONLY if the park brake is ON and the mower is NOT engaged.
What I'm thinking is that the switch under the seat is not working, and the machine thinks that no one is on the seat and in control.
May 17, 2015 | Garden
How to repair cruise control?
Try from Servo control follow connection To I beleive Transmission casing . Look for Burnt wiring / frayed / damaged ...Cruise should maintain speed signal Like speedo cable . Computor management black box / ECM may have direct control so Look for engine bay fuse boxes = 2 under hood . More fuses ++ relays 2 check inside cover is diagram of size + what it controls . A Reset 2 ecm may help by disconnecting Battery - Let sit 30 mins.. Older models + 4 wheel drive Trans has Gear wheel of plastic 2 count revolutions as speedo cable does . If said wheel teeth have worn out then Cruise counts incorrect or fails 2 activate . If you replaced brake pedal Light activation switch then be sure brake Tail lights DO work if not the cruise will fail as brake pedal is part of safety feature to turn it off in emergency disconnect . The signal light Stalk that Turns off L / R signals is Common Item 2 wear out BUT it also controls Turning on cruise or setting ...IF you have Steering wheel on / off / setting control - then issue can be frayed / cut wires due 2 steering wheel movement ....solutions remove wheel BUT 1 st disconnect Air Bag Fuse then wheel and search connections .....Good Luck ...
Apr 16, 2015 | 2002 Chevrolet Tahoe
Engine fault is on; mechanic said it's because of the cruise control; just need a second oppinion
We can't give that
Your asking for a guess at the unknown
You get to the shop & into the service bay &
be part of the solution & get your answers up
close & in person,your paying,get the education
Doesn't matter how it runs to you
You have fault codes & a repair to be made
Aug 26, 2014 | 1997 Jaguar XK8
98 manual vw passat cruise control not working any ideas to start and find the problem
Apr 08, 2014 | 1998 Volkswagen Passat
98 manual Vw passat cruise control is not working any help on where to start to find the problem
Apr 08, 2014 | Cars & Trucks
John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I own a 2005 GMC Canyon Five CYL and the cruise control stopped working last niight. You push the button and no cruise. I checked the fuse and it is ok I exchanged with another 10AMP and no change still...
Start with the simple and check the fuses and the Stop lamp switch. Check your brake lights, if they're not working, the cruise won't work either. If they're not working, check the fuse for them, if the fuse is fine, then take it into the dealer, there's been a recall issued on the brake switch, so it should get fixed for free.
Cruise Control Disengaged
The powertrain control module (PCM) disengages the cruise control operation based on the signals from the following switches:
* The stop lamp switch
* The TCC brake/cruise release switch
* The clutch release switch, if equipped
* The cruise control On/Off switch
The TCC brake/cruise release switch and the stop lamp switch are mounted on the brake pedal bracket. When the brake pedal is applied, the normally closed TCC brake/cruise release switch opens and the normally open stop lamp switch closes. The PCM detects a low signal voltage on the TCC brake/cruise release switch signal circuit and a high signal voltage on the stop lamp switch signal circuit. When the clutch pedal is applied, the normally closed clutch release switch opens and the PCM detects zero voltage on the CCP switch signal circuit. The vehicle speed stored in the memory of the PCM will be erased when the cruise control On/Off button is turned OFF, or the ignition switch is turned OFF.
The Cruise Control System will disengage when the PCM detects that a driver override function has been active for approximately 60 seconds .
When the Cruise Control System is disengaged, the PCM sends a class 2 message to the instrument panel cluster (IPC) in order to deactivate the cruise control indicator.
Cruise Control Inhibited
The powertrain control module (PCM) inhibits the cruise control operation when any of the following conditions exist:
* A cruise control related DTC has been set.
* The vehicle speed is less than 40.2 km/h (25 mph) .
* The vehicle is in PARK, REVERSE, NEUTRAL, or 1st gear.
* The engine RPM is too low.
* The engine RPM is too high, with fuel cut off.
* The vehicle speed is too high, with fuel cut off.
* The system voltage is not between 9 volts and 16 volts .
* The Traction Control System (TCS) is active for more than 2 seconds .
Thank you for using Fixya and start with replacing the stop lamp switch. Even though the brake light work, it;s been known for that switch to cause your issue. that's way there was a recall for it.
Apr 01, 2010 | 2005 GMC Canyon
Craftsman garden tractor quits when brake released.
It sounds like your throttle cable is caught up with the brake pedal.
Oct 01, 2009 | Garden
1995 sable cruise control quits, speedometer works fine as does engine,, etc, just no cruise control anymore. Any suggestions.
Check the brake switch. There are two, one for the cruise and the tcc, and one for the brake lights and shift interlock
Mar 01, 2009 | 1996 Mercury Sable
Cruise Control
make sure brake lights are working,if working brakepedal switch fine.it is most likley the cruise control cut out switch.blue and white switch on brake pedal.
Oct 20, 2008 | 2000 Ford Expedition
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
324 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
