Question about Kenmore HE2 Plus Front Load Washer
What is error code 20 and how do I fix it? - Kenmore HE2 Plus Front Load Washer
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
F20" on display
(Water Inlet Problem-no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
1. Are water faucets completely turned on?
2. Are screens at inlet hose connection to washer
clogged?
3. Are water inlet hoses kinked?
4. Are water inlet hoses frozen?
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Jan 02, 2011
  • devans033 Apr 21, 2011
    Very helpful, thanks!
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Scanner error 20?
Here is a link to help with HP LaserJet Error Codes.
Go through them, follow the procedures and you may find this useful and helpful.
http://printertechs.com/tech/error-codes/error-codes-index.php
Also, this link below, however, explains what Error 20 is and how to fix it in a "little" more detail.
--Printer Not Activated - Error 20--
I hope these help you.Regards, Mike
Mar 24, 2015 | HP LaserJet M1005 Printer
How to fix error 20 on 1100D canon camera
U have to fix this by the way of getting new button. U can get it on ebay or aliexpressm, etc. Disassemle the front side and button section, get out old button, than put new button and settle it down with trigger. And that is all! Good luck!
Dec 25, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
F 20 Error code washer won't fill up.
http://www.fixya.com/support/r3608632-f20_error_code
Jun 03, 2010 | Kenmore Elite 45986 Front Load Washer
E020 01BO What does this error code mean?
E020 indicates a Black Toner malfunction. If you've recently changed the toner and failed to distribute the toner by gently shaking it from side to side, this could be the cause of this error or if the toner is very low it could trigger the same error.
01B0 is a drum error related to your toner error message. If toner cartridge is good, remove the cartridge, clean the drum, replace the cartridge and both errors should clear. A dirty drum will also trigger your 1st error e020.
Nov 16, 2009 | Canon CLC 1120 Color Copier
I keep getting error 20. How do I fix it.
error 20 in a general error try to Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash.
Sep 19, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
Nov 19, 2008 | Panasonic Workio DP-3530 Copier
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Kenmore HE2 Plus Front Load Washer Logo
237 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
