Question about Gateway Computers & Internet
Gateway laptop p-6822; possible inverter problems - dark screen on bootup?
  • 97 Answers
Does it matter if the computer is plugged in or on battery? If its the same either way, yes most likely its either the inverter or "backlight". A good way to test is , plug it in the and external monitor and see how the picture is.
Posted on Jan 02, 2011
How do i rotate my computer screen
Grab the laptop, and roll it over on it's side
OH, I'M JUST KIDDING!
Hold the CTRL key, and ALT key down at the same time.
Tap on the Up Arrow key until the screen is where you want it.
Regards,
joecoolvette
Apr 06, 2013 | Gateway 6822 Notebook
Gateway ml6731 black screen
It is possible that it is the main board or motherboard that is having problems. it is possible that the video card is having troubles.
Jun 05, 2010 | Gateway ML6731 PC Notebook
Got gateway w340ua laptod with a dark screen i already change the lcd and the inverter and still is dark... any sugestion...also i can used with a external monitor no problem
The LCD connector cables are probably not plugged in properly. Since it works with an external display it cant be anything else. The connectors are inside the cable. If you are sure that the connectors are fine then you will probably have to replace the LCD inverter board. Hope that helps, Sai.
Jun 11, 2009 | Gateway 450ROG Notebook
Gateway laptop- screen went dark but is still on.
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 31, 2009 | Gateway 450ROG Notebook
Screen stays black when booting up on Gateway laptop
there is a inverter in lcd that makes shinely, white .
it looks like inverter issue. need to get service.
May 29, 2009 | Acer Aspire One PC Notebook
Lcd of my gateway laptop lost ligth inside so is to dark but i can see the destop icons but is to dark
Your Backlight bulb has burned out, or the Inverter for it.
1.General information on replacing a Backlight lamp,
(Bulb)
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
2.General information on replacing an Inverter,
http://www.laptoprepair101.com/laptop/category/replacing-screen-inverter/
May 28, 2009 | Computers & Internet
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
I'm betting that you need a new "Inverter" board, especially if it's a Gateway 450ROG.
There is an inverter that Gateway used in several models that has a known defect.
Inverters are relatively inexpensive ,and easy to replace. You could ven do it yourself if you have a little skill at disassembly / re-assembly. Tell me the model number of your laptop and I can help you more
Apr 10, 2009 | Gateway 40G / 40GB for laptops /...
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Mar 13, 2009 | Gateway MX7118 Notebook
Compaq laptop with dark screen
It is possible that the problem is in the video card - that it's just not turning on the backlight. But it's so much more common for it to be the backlight or inverter that I'd try to get a second opinion.
Jan 24, 2009 | HP Compaq Presario V2000 Notebook
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
