Question about Whirlpool ET8GTMXK Top Freezer Refrigerator
Whirlpool ET8GTMXK Top Freezer Refrigerator: just want to the the dimentions of the product. h, w, d, cubic ft.
  • 15 Answers
SOURCE: Need Cubic Foot Capacity of this refrigerator please
Find a five year old child with a tape measure
and ask the child to measure the inside of the fridge
then width x lenght x hight = result
Then give child a lollie
Posted on Apr 16, 2009
SOURCE: Water interior of fridge....GE profile 21.6 cubic ft. model #TBX22PIYMRBB
i have this problem .whats the fix
Posted on May 29, 2009
  • 19 Answers
SOURCE: The freezer is working but the refrigerator is not
I have the same one. It was outside in the garage-brand new-had that same problem. We taped foam insulation on sides and parts of the back-that worked! We have since moved and now it is in the climate controlled basement and works fine w/o duct tape! get what you pay for huh?!
Posted on Sep 01, 2009
tomsat69
  • 219 Answers
SOURCE: My Whirlpool 21. cu. ft top freezer drips water
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the refrigerator from the ceiling adjacent to the floor of the top freezer. the Freezer back t-shape vent goes down to these inlets where the percipitation is coming from. What is this the damper
Posted on Mar 17, 2010
  • 77 Answers
SOURCE: Whirlpool 21.0 cu. ft. Top Freezer Refrigerator
With ice makers it is almost always one of two things. The ice maker itself, or the water valve (valve is located on the backside of the frig, bottom right hand side almost 100% of the time). Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker.
Posted on May 30, 2010
Need to know how many cubic feet my frig is so I can compare when shopping for another.
This is the information I could find.
Refrigerator Type Side-by-Side Total Capacity Cu. Ft. 21.7 Cu. Ft. Refrigerator Capacity Cu. Ft. 14.40 Cu. Ft. Freezer Capacity Cu. Ft. 7.30 Cu. Ft. Energy StarĀ® Qualified Yes
for more information try this link.
Whirlpool Appliances for the Home Kitchen and Laundry Room
Bob
Mar 16, 2015 | Whirlpool Refrigerators
I need to know the cubic ft of my old Whirlpool fridge. The model# ET18JKXDW01. Serial# 18TFA95. Thank you.
The first two numbers in the model number says what the cubic feet is, its 18 cubic feet
Gene
Aug 10, 2011 | Magic Chef CTF2125 Top Freezer...
The freezer keeps leaking water into the refrig box. i've cleaned out the freezer and wiped it down and can't see anything built up....can you advise me on the next step? thank you
Sounds as if the defrost drain line is plugged somewhere. You have to find the line and clean it out.Sometimes you can get to it from inside the refrigerator and sometimes you need to move the unit out and you can get to it from the back,
May 16, 2011 | Whirlpool ET8GTMXK Top Freezer...
The drain line is plugged allowing water into the inside of the fridge. How do I unplug the line?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Whirlpool ET8GTMXK Top Freezer...
How many cubic feet Whirlpool ET8WTMXKT07?
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Aug 28, 2010 | Whirlpool ET8WTMXK Top Freezer...
Freezer has alot of frost build up and the refrigarator has water leaking and running under vegetable trays in bottom and freezing what could be wrong It is a whirlpool top freezer 21 cubic ft and is 2...
Hi, this sounds like a problem with a blocked defrost drain. For full instructions on clearing the drain from my tips click HERE . If you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping inside refrigerator under crispers, but
I have a Whirlpool Designer Style 25.1 cubic ft. refrigerator and it looks like we will have to get a new one. There doesn't seem to be any way to get to the hose to unclog it. Thanks.
Jul 06, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Frige is getting to about 50 degrees
Your refrigerator has a adaptive defrost circuit bord part number 4388931 If the board or the defrost elements inside the freezer are not working properly the defrost will not work. You can visit my site and enter model or part number into the search feature. We also offer free assitance to help get you going again. (click link below) Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 26, 2009 | Whirlpool ET8GTMXK Top Freezer...
Whirlpool ET8GTMXK Top Freezer Refrigerator Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
