Question about Frigidaire ATF6000ES Front Load Washer
When i start a new wash program it fills up with water and starts to aggitate but it does not move on to the next step in the program. i can move the dial on and then it gets stuck on that next step.
  • 1 more comment
  • scq325 Jan 03, 2011
    Hi Rich - i was asking about a Whirlpool LSR8233EQ1 top loading washer. Not a Frigidaire Front Load Washer. Can you provide a solution for the Whirlpool washing machine? Thanks
    Thank you! Can you provide some help on how to install it? Is it complicated?
    I have ordered the part and will install it when it gets here. It sounds like it will work! Thanks!
  • Frigidaire Master
  • 8,220 Answers
I can give out some links for service manual:
Affinity manual
More manuals here
Frigidaire service manuals----- User: service ----Password: tips
Posted on Jan 03, 2011
  • Dan Webster
    Dan Webster Jan 03, 2011
    I saw the same thing you are describing on a top loader. The plug that goes into the timer had backed out slightly. I cleaned the corrosion and pushed the plug back in. No parts were needed.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Missing cycles or if the timer won't advance, you have bad contacts within the timer which is part of the "control board".You will need to replace the "control board" on your washer. Here is a link to the part.
Posted on Jan 02, 2011
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Washer was filling but not aggitating,
remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway ..mm
Dec 12, 2009 | Maytag PAV2300 Top Load Washer
Washing machine continues to fill when starts
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Oct 01, 2009 | Washing Machines
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Have a ge washer, filss then does not progress to
May be a bad water level switch.
Open the control panel, with a full tub of water bump the water level switch with your hand. If it starts to agitate, replace the water level switch.
Mar 20, 2009 | Maytag Performa PAV2200
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
Frigidaire ATF6000ES Front Load Washer Logo
172 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
