Question about Aiwa Z-R555 Shelf System
I have an aiwa compact disc stereo system Z-R555, which plays 5 cd's. It was purchased new in September of 1998, so it is 12 years oldf. The radio has never been used. The tape player has never been used. The record player (top unit) has never been used. Only the cd player portion of the system has had daily use in our home and has never been cleaned. To play a cd, it will not start immediately. After turning the unit off, then on and arrow to play, it will finally begin, only then to stop in the first 1-2 minutes of play. Can you tell us if you think the unit just needs cleaning, or is it a cleaning and age problem? Can only the cd player portion be replaced, if needed? Thank you for any help. Elaine
4 Suggested Answers
SOURCE: HOME STEREO SYSTEM CD PLAYER
aiwa cx-na508
Posted on Jul 28, 2008
hardrocko
  • 1476 Answers
SOURCE: I have a Aiwa stereo system that has a turn table,
fullmoon5220,
You need to replace the belts and clean all the moving parts. If you look at the rear of the unit you should see about 6 to 9 recessed holes. They have screws that you need to take out to take the unit apart. Remember to unplug the unit first. There could be more screws and even a couple on the front under the cassette doors. Every unit is different and you will just need to be careful and not force anything.
Once the unit is in two halves you should see the belts. Measure the belts with a ruler for length, and go on the short side because they will be streched. Go to http://www.mcmelectronicsinc.com where you should be able to match up the belts. Also order some contact cleaner to clean the capstan, rollers and heads. In addition get some lint free Q-tips to clean all the parts.
Use the cleaner on the capstan, pinch roller and the load mechanism. Install the new belts and reassemble the unit. If this was the only problem you should have a working unit.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Mar 06, 2011
ekcnoel
  • 998 Answers
SOURCE: I have a Z-L70 compact
This trouble is very common to this model the system control ic is already damage I suggest that you should bring it to the service center and this parts is not available to the market. Good day and best regards.
Posted on Aug 07, 2011
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
I have an old Aiwa stereo with a 5-CD changer. The remote control has RC-7AS05 on it. How can I program the CD player to play the CDs continuously?
Press the RANDOM/REPEAT button and watch the unit's display. There will be a graphic changing to show the different functions: Disc repeat....All Repeat.
Try out the different modes unit you find the one that plays all the discs in the carousel.
Sep 16, 2014 | Aiwa Audio Players & Recorders
Why does radio keeps turning itself off after 15 min.?
Half a dozen reasons... If it's exactly 15 min maybe a timer is set? If it's only when it's played loudly or when a bass part is played it could be the wires touching each other.
Jun 07, 2014 | Sharp Cd-dh950 Cd-dh950p 5-disc Compact...
Can music be transferred to computer and then be burned to cd
(Yes) What do you mean by transferred to computer? A stream (music play like a radio) a Download (a file saved to your computer) to record a stream to a audio cd recorder is easy. You need a cable with a 3.5m plug one end and 2 RCA plugs on the other end (red and white plug) Use the plug that looks like a headphone plug, plug that into the computer headphone or speakers and the others into your stereo red into the red hole and white into the white hole choose (AUX) now play the music from your pc you should hear it playing out from your stereo. Your all set. (have fun)
A download: A music file is stored on your computer. When you choose to download a file always remember what folder it is in! for a mp3 file you can use windows media player to burn cd. (must have a CD or DVD Burner installed in your computer to do this) if not don't fret just see above it will also work on downloaded music.
Feb 05, 2010 | Aiwa Z-R555 Shelf System
Aiwa Z-2300 compact disc stereo system
need to buy the laser for it's CD . where can i buy it from
Feb 20, 2009 | Aiwa Audio Players & Recorders
CD's won't play on AIWA Compact Disc Stereo System
I have a Aiwa Compact 3 Disc Stereo Systen that will pick up the 1st CD, spin it for about 5 seconds, lower it and then go to 2, same thing, on to 3 and same thing. Please help.
Oct 30, 2008 | Audio Players & Recorders
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Oct 25, 2008 | Aiwa NSX-DS55 CD Shelf System
Aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Mar 30, 2008 | Aiwa CDC-X304 CD Player
YAMAHA CD PLAYER WON'T PLAY
GG  My kids had a PlayStation 2 that did this and so did my AIWA 3 CD player.  The solution for the PlayStation was to remove the cover use alcohol and clean the lens of the laser reader.  They get dust on them and simply cannot read.  The AIWA required replacement of the laser which cost almost as much as the unit and didn't last 6 months.
Oct 17, 2007 | Yamaha CDC-565 5-Disc CD Changer
Aiwa Z-R555 Shelf System Logo
87 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
