Question about Samsung HL-S5087W DLP TV
Why is my Samsung DLP Television is making a static noice when turned on?
  • 47 Answers
Hi, what do you mean by static noise. Is your station unclear. Does this only happen on the cable coax connection or is it a loud noise. If its a loud noise then its your colorwheel if its an unclear station or channel then more then likely its your main input board. Please let me know if that helps any.
Posted on Jan 03, 2011
Samsung dlp has static
I have seen this happen quite a bit. For some reason the input (cable jack) works loose from the board. I would try running your source signal (cable/dish) to another input on your tv...such as S Video/HDMI/Composite or whatever you have available.
Jan 07, 2013 | Samsung DLP HL-P4663W 46" Rear Projection...
My Samsung DLP HL-P4663W 46 in. turns off every minute and a half. already replaced the bulb, and the timer, lamp, and stand bye flash after turning off.
hello make sure the lamp is fitted securely and the lamp cover as well as there are safety switches. you might have reset the lamp counter hope it helps
regards
shaun
Jan 02, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Samsung DLP HL-R5667W, seeing little boxes of static flashing
samsung color weel replacments are all the new air bearing type insted of fluid type. if you replace the new color weel , color will look bad. also note when ordering your replacment make shure it comes from samsung and not just a generic model.
the original replacement will come with a set of instroction to reset the dmv ajustments.
find the dmd pcb and look for a2 jumper that is visable through a small squaire remove the jumper. then folow instrustions with new color weel.
hope this helps.
regards,
daniel.
Jan 13, 2009 | Samsung DLP HL-P5663W 56" TV
Remote stopped working after color wheel replaced
See http://www.consumermeet.com/entry/samsung-remote-wire.html , that seems to address the same problem.
Aug 26, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S5087W DLP TV Logo
444 people viewed this question
Henry  Thomas
Henry Thomas
