Question about Frieling USA Inc. French Press 0104 Coffee Maker
I have a frieling french press. On the second plunge, the plunger came loose. It won't stay connected to the filters. It appears to be stripped. Can I get another plunger unit that isn't stripped?
Why does water filter leak when tightly connected but not when loose?
It makes sense if there is a crack in the filter housing that is made more severe by tightening the fitting. Also, a fitting could be stripped from overtightening.
Aug 11, 2015 | Whirlpool Refrigerators
Clogged lavatory
Most lavatory clogs can be cleared by the use of a plunger It
may take some time or a matter of seconds....keep plunging....
I hope you have a plunger. If you are not able to clear the clog
you will have to call a plumber. Remember....constant suction
is the key.
Regards,
Dennis
Sep 27, 2014 | Home
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
Feb 02, 2013 | Samsung RF4287HARS French Door...
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
Soap dispenser cover latch will not stay in the hole. So now the soap holder will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Every French press i have bought works well the first couple of times then the screen on the press bends and creates air pocket which when pressing explodes coffee grinds and hot water everywhere!
The trick with any manual French Press coffee maker is to very slowly press the plunger down, after you've allowed the ground coffee to steep/brew for the time you prefer.
I've got an older French Press carafe and had my share of "bent" screens from being too quick when pressing. I finally learned that the slower I pressed the better the unit would survive and the better quality of coffee I'd get as a result.
French Press coffee is not a quick process, what with the boiling water and fresh ground coffee beans and the steeping/brewing dwell time needed to get the hot water infused with the coffee and the very slow pressing filtering process needed to extract the full flavor of the coffee from the ground coffee and water.
Take your time in pressing your coffee and enjoy the great, fresh taste from your efforts.
Hope you find this Very Helpful and best regards!
Nov 10, 2009 | Bodum 's BRAZIL french press coffee maker...
Assembly
turn the filter upside down (opposite the way it is now)
Should help
May 05, 2008 | Bodum 's BRAZIL french press coffee maker...
Frieling USA Inc. French Press 0104 Coffee Maker Logo
60 people viewed this question
Top Frieling USA Inc. Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Frieling USA Inc. Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
