Question about DISH Network IR Remote Control
How do I progam my remote so it works with dish.. it seems to be stuck on only TV setting, not on SAT!
    Scholar:
  • 25 Answers
Hello, this is Matthew Gonzales with DISH Network. If the remote will not change from "TV" mode to "SAT" mode, try changing the batteries first. If changing the batteries makes no difference and you still can not get the remote to change to "SAT" mode, the remote is defective and needs to be replaced. If it does change to "SAT" mode, but is not working you can try putting system info on your screen, (power off the receiver using front panel button, the press "up" arrow on the front of receiver). When systeminfo is on your screen, on the remote press the "SAT"button one time, and then press the "record" button threetimes. Try pressing select to see if it is now working. You canalso try to hard reset your receiver. To perform a hard reset, you unplugthe receiver from its power outlet, wait 15 seconds, then plug it backin. Try reprogramming the remote again with the first part of theseinstructions. If the remote is still not working, it may be faulty. If this has not been resolved please feel free to email me at matthew.gonzales@dishnetwork.com. Hope this helps!
Posted on Jan 02, 2011
  • 38 Answers
Get a universal remote
Posted on Jan 03, 2011
I have a RCA tv in our rv connected to Dish Network. What are the channels and input for the rca tv? The model is L32HD41
Try ch 3 and sat or cable input on tv. use menu on original tv remote to set input as sat or cable.. then use dish remote for all other changes.
May 15, 2017 | RCA Televison & Video
Dish Network Remote Codes? Can't seem to get the few I have to work the dish remote
If your remote is a learning remote (has a little black glossy square on the top left side of the remote) you don't need a code, you just need the original remote. Place both remotes on a table, or other flat, sturdy surface, with the original TV remote facing the square on the DISH remote. Make sure both remotes have functioning batteries. On the DISH remote, hold down TV until the button blinks three times, then hold down record (for 5+ seconds) until the TV button lights up and stays on. Then, slowly, for each key you want to use, hit the key on the DISH remote (TV light blinks) then the corresponding key on the original remote (TV light blinks). For example: DISH Volume Up, TV remote Volume Up. When you are done learning all the keys you want to train, hit SAT. The TV light will blink three times, then the SAT light will light up for a moment. Try the DISH remote on your TV functions.
Nov 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Dish Network IR Remote's SAT Mode Not Working ________________________________________ I programmed my Dish Network Remote (IR 1.5 Blue Button Remote Control ) for my Sharp 27F543 and now the remote would...
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
  1. Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record.
Hope this helps!
Jan 01, 2011 | DISH Network IR Remote Control
The tv is jammed. Remote is fine but have pressed the wrong button
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
Oct 01, 2010 | DISH Network IR Remote Control
I have 2 dish remotes #103602. One works fine the other suddenly will not allow any of the lights except TV to come on. It will not let the SAT button light up. The remote will control the TV but not...
bdmills04
Have you replaced the batteries in the remote that is not working. If batteries are low, the lights will still light up but will not operate the functions for the remote. When you press and release the SAT button, what happens? If you try to press the SELECT button, does the TV button light or the SAT button? If you have already tried these steps, you may need to readdress the remote to the receiver. I have provided a link with the instructions on readdressing the remote. I hope this helps.
Readdressing the remote, step 5:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Aug 18, 2010 | DISH Network IR Remote Control
My dish network remote stop working
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux mode. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Mar 11, 2010 | DISH Network IR Remote Control
TV 2 remote, have to use the TV remote instead of Dish remote for the volume control
You will need to program your dish remote to your tv, find the 3 digit code for your tv and on your dish remote press the TV button till all lights light up at the top of the rem, then enter the 3 digit tv code and then press pound. this will now programm that rem to your tv. be sure to press the SAT button to put back into SAT mode to operate your Dish programming.
Nov 01, 2009 | DISH Network IR Remote Control
I can not control the mute or volume with the remote through the Sat mode. It only works through the aux mode. It is connected to a Onkyo receiver.
Dish remotes are set up to operat between SAT and TV mode simultaneously to control these features on a stand alone TV once you introduce the receiver you lose that ability as it is a seperate piece of equipment. You could try entering the code for the receiver to the TV button but I personally have never had any sucess with that approach. In short you are stuck using the remote as you are currently or are left with purchasing a universal remote. Thanks for using Fix Ya,
May 06, 2009 | DISH Network 311 DTV Receiver
Brand new dishnetwork 622 DVR UHF remote does not work
Contact Dish Network tech support. If they can not fix it for you over the phone then they will send you a free replacement. Hope this helps.
Apr 01, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
DISH Network IR Remote Control Logo
467 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
