Question about GE Dryers
What is the configuration to install the belt
  • 472 Answers
You need to place the belt completely around the tub which requires removing the front panel...once you get the belt around the tub you will bring the belt together in one hand under tub area.place the belt around the motor shaft while pushing the belt guide to the side... the best explanation i can give is its like a pulley on a car the tensioner rest on the belt to keep it tight during operation. hope this helps
Posted on Jan 02, 2011
BELT PULLEY WILLNNOT STAY IN PLACE SO BELT KEEPS COMMING OFF
... Sometimes it has to do with the correct measures of the belt (there are many sizes and materials), you should check that if you changed the belt.... Another possibility is that the belt is too worn, or the pulley that support the belt has to be adjusted.
Mar 15, 2016 | Dryers
I need a fan belt diagram, please.
If you go to autozone they have those for most cars and a lot of other diagrams and install directions
Mar 26, 2015 | Cars & Trucks
Install a belt tensioner in 2004 freestar
2004 Ford Freestar:
Accessory belt drive removal and installation:
    1.Put the vehicle in neutral, and put it on hoist.
    2.Rotate the accessory drive belt tensioner counterclockwise.
    3.Push the spring clip towards the belt tensioner to lock the accessory drive belt tensioner in place and remove the belt.
    4.To install the accessory drive belt, on the engine, rotate the accessory drive belt tensioner counterclockwise till the spring clip releases.
    5.Install the belt.
Jan 31, 2015 | 2004 Ford Freestar
Installing drive belt
If it is a serpentine belt, there is a sticker on the radiator bracket that shows the configuration. You move the belt tensioner pulley to release the tension on the belt, replace the belt, and move the tensioner back into place.
Jan 05, 2014 | 1988 Chevrolet C/K 3500
Need to know the configuration for installing a new belt on a Whirlpool AWA9708 7kg dryer
your model number doesn't show up but all whirlpool belts go on the same way,put the belt under the idler pulley and then onto the motor pulley,you have to push the pulley back towards the motor and then loop the belt onto the motor pulley and you want the ribs to be down touching the drum
http://www.youtube.com/watch?v=CFnXwmUb4f4
hope this helps and next time send the full model number off of the machine,just open the door to the dryer and look around the opening where you put the clothes in you'll see a tag with the full model number
Apr 09, 2013 | Dryers
Lookng for serpentine belt routing diagram for 1998 2.4 L sunfire
1998 Pontiac Sunfire Belt Routing Diagram
A drive belt routing diagram is needed when replacing a drive belt to help simplify the installation process. The problem arises as there are many different ways a drive belt can be configured. In this configuration the belt length will vary not allowing the belt to be installed. Also alternative configurations could turn a particular accessory the wrong direction, creating more problems. Always reinstall the drive belt in the exact configuration as the previous belt to prevent these problems. Always use high quality replacement products to avoid premature drive belt failure. If a multi rib drive belt fails it must be replaced immediately to avoid such situations such as engine overheating and loss of the power steering system. Whenever a belt replacement is required inspect the pulley condition to ensure there are no sharp edges on any of the pulleys, this will cause the belt to shred and fail. Confirm that all pulleys are free from debris such as small pebbles, these pebbles will cause the belt to pit and significantly impair the belt performance. The belt tensioner plays an important role to the drive belt performance, if this tensioner is weak it can allow the belt to lose tension allowing the belt to jump and skip. This condition will result in noises such as squeaking, chirping and ticking.
Hope helps (remember rated this help).
Jul 11, 2010 | 1998 Pontiac Sunfire
Belt diagram
Hope helps (remember rated this).
Jul 11, 2010 | 2004 Chevrolet Cavalier
How to install serpentine belt on 1996 dodge caravan se
Good morning! I am enclosing a serpentine belt routing diagram to aid in the installation of your serpentine belt. There are 4 different engine possibilities but i have enclosed all. The serpentine belt tensioner is released by rotating in a clockwise direction as shown in the diagrams. Engine configuration will determine what tools you need but the installation is relatively easy to do. Have a great day!4c86670.gif8f5ea2e.gif68b7bf5.gif
Oct 04, 2009 | 1996 Dodge Caravan
Hope this helps! If the belt seems too long for this configuration, some later models route differently to get more contact with the alternator pulley to reduce slippage:
Apr 08, 2009 | 1995 Volvo 850
Serpentine belt
possibly. was ir screeching before you replaced the belt?
Sep 03, 2008 | 2002 Ford Windstar Cargo
Dryers Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
