Question about True TD-50-18 Beverage Cooler
Cooler runsa few minutes and compressor and compressor fan stops, will reset and do same thing over, will get to about 45 deg? I put a quick start kit on but no help.
2 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MIN.
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
Posted on May 03, 2009
Auto/On set to ON. Fan runs.
Sounds like the thermostat, the way to verify is to unplug indoor unit, remove thermostat, take pic of wiring with phone or label the wires as to the terminals. Carefully twist the yellow,(Y) Red (R) and the green (G) together. Plug the furnace back in, if the unit operates normally, replace the thermostat. I am basing this on the fact that the blower speed is changing. This could also be an anomaly within the circuit board in the furnace section, not likely though as the outside unit (condenser) is not controlled n by the indoor board unless this is a heat pump. hope this helps. D
Jul 21, 2015 | Dometic Rooftop RV Air Conditioner
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
My Samsung RS2630SH fridge and freezer are not staying cold. The condenser fan is running, I blew and vacuumed all dust off of the coils. If I unplug it for a few minutes then plug it back in the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 09, 2011 | Refrigerators
Motor seems to be running, but nothing gets cooled
Hi there
You think the motor is running this can often only be the fan inside, the only way to check if the compressor is running is to pull the unit out listen carefully. You can feel the compressor to see if it is running but BE CAREFUL, if the compressor has a problem it can get to around 180 deg f (80 deg C) you may have to use a glove, or with the unit switched off and unplugged wet your finger then touch the compressor, any moisture will evaporate very quickly if it is hot. There may also be a fan on the condenser, check if this is running.
1. If the compressor is cold it is likely that there is no power going to it from the thermostat this is a very common failure and fairly easy to do if you feel competent.
2. If the compressor feels hot and there is a fan next to it which does not run then it is likely to be the fan.
3. If the compressor is hot and the fan is running try cleaning the condenser grille gently with a soft brush and vacuum cleaner.
4. If 3 above is OK and still nothing then either there is a problem with the gas charge or there is a problem with the compressor, either of these will need your local reputable service guy.
Let me know if I can help further
Gordon
Apr 27, 2011 | Oster 12-Bottle Wine Cellar - Black
Can you tell me the order in which each componet of a gas furnace comes on to start the furance?
Yes there is a sequence:
0:00 Dial for fan/limit switch is at 70 deg position. Furnace is cold. I turn T-stat to 80 deg to start furnace.
1:00 Burner comes on and dial begins to move slowly up.
2:30 Dial at 140 deg and fan motor comes on. Dial never goes above 150 deg.
3:00 Burner turns off. Dial slowly moves back towards 90 deg.
4:45 Burner turns on and dial is at 110 deg.
4:50 Fan turns off with dial still at 110 deg.
5:30 Burner off. Dial at 120 deg.
6:15 Fan on. Dial at 140 deg. Burner is still off.
7:00 Burner on. Dial at 120 deg.
7:40 Burner off. Dial still at 120 deg.
8:30 Fan off with dial at 110 deg., and it quickly snaps back to the 80 deg. position.
8:30 plus, cycle continues.....
Mar 25, 2010 | Heating & Cooling
Where can I get a wiring diagram for an under-counter Beverage-Air cooler. The condenser runs then stops after a few seconds. Figuring a bad relay? The power runs but the condenser kicks off immediately...
If it's the condenser fan you are talking about you will not need a wiring diagram. The fan should be wired to the compressor and the thermostat. the thermostat is the relay to start the fans and compressor. I will continue to look for a wiring diagram. When the fan wears out they will stop causing the cooler to overheat. I think replacing the fan would be what you need. I believe that Beverage Air used the Copeland compressor with the condenser fan mounted on the one end of the the same slide in compressor. Check your voltage on the 2 wires going to the fan. When compressor is on the fan should also be running. I just have the feeling that condenser fan is defective.
Sea Breeze
Aug 19, 2009 | Refrigerators
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Fridge not running well
Not sure of what type of fridge you are refering to.. However you can try a few obvious things. Try turning the thermostat to a lower number (warmer setting) to see if that makes a difference. If you have an ice build up starting to form on the fridge plate or only a partially cold plate then you could have either a loss of refrigerant or compressor fault. Is the compressor noisey in comparisson to its normal noise. Is there heat being produced all over the condenser (black finned section on back of cabinet or underneath cabinet)..If not possible gas leak. Hope this is of some help.
Sep 07, 2007 | Haier BC112G Wine Cooler
True TD-50-18 Beverage Cooler Logo
23 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
