Question about Bosch Dryers
Bosch wta 3600 Dryer stops mid way, filter light lights up and dryer stops. Cleaned filter, but to no avail.
SOURCE: bosch maxx wtl 6300 dryer when
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer.  Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..  I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
Posted on Oct 25, 2008
ttdesignbilt
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
I had the same problem and figured if the lint sensor is clogged, covered or otherwise gummed up with lint, dirt, hair, etc then this will continue to happen regardless of wether the lint trap is clean.
So I took my compressor and blew out the slot where the trap slides into...stuff flew everywhere (so watch your eyes or wear goggles). I then vaccumed it up and did it again... and again and again each time loads of stuff came out. Once nothing blew out I loaded the dryer and have not had the problem since...
This makes sense right? so if you can try this solution.
Posted on Jan 24, 2009
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
maklean
  • 1665 Answers
SOURCE: Service Manual
http://www.servicetechhelp.com/index.php/downloads/6124
Posted on Jun 26, 2008
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
Dryer heats and runs but clothes are not completely dry. the lint light comes on. have cleaned lint out of dryer including behind and underneath
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 21, 2011 | Bosch Axxis WTA 3500 Dryer
I have a Bosch V20-Ul dryer that is 2 years old. Suddenly stopped creating heat. The dryer drum turns but no matter which cyle I select, it spins for about 1 min, then stops, beeps and the wrinkle block...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 09, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Why does my bosch dryer wta 2910 only blow cold air?
If the exhaust vent tubes have never been removed and thoroughly cleaned in years this will cause the sensor to keep the heat off in your dryer. If clean the moister sensor is at fault
May 02, 2010 | Bosch Axxis WTA 3500 Dryer
Bosch Axxis dryer - lint filter indicator lights up
Make sure the exhaust vent duct is clean all the way to the outlet.
Nov 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Lint filter light comes on and smells like smoke from inside the dryer. No lint in lint filter
You need to vacuum the lint from the entire vent system from the door to the outside vent. Wash the lint screen in hot water and detergent to remove fabric softener sheet residue which plugs the screen.
Sep 27, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Drive Belt on BOSCH WTA 3003 dryer
No,It`s quite a difficult & fiddly job.
Nov 10, 2008 | Bosch Axxis WTA 3003 Electric Dryer
Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer venting
i think you will find that one of these caps should be off and preferably connected to a vent hose to go outside the house. the reason they are blowing off is that the air has nowhere to go
Jun 26, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
235 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
