Question about Dewalt Saws
DW718 miter saw. The blade rotates but does not cut once it makes contact with any resistance. It is as if a cotter pin is broken. How do you repair the problem and what parts would I need. Was working fine and there was nothing to indicate a reason in the cut or the previous as to why it all of sudden occured.
  • 2,527 Answers
I have 8 differant saws but not a dewalt and have not ever heard of or seen a shear pin on a drive shaft of a motor its a stright shot through the motor to the brushes and there is no gearing or reduction box I would say check the blade connection and washer assembly or the end bearing on the shaft may be worn out and binding under a load. Dose the blade spin true or can you wiggle it from side to side and feel play in the bearing I soppose it could also be some kind of electrical issue where something is shorting under load but that would still bring me back to movement in the shaft that is binding the motor.
Posted on Jan 02, 2011
My Dewalt miter saw DW718 seems frozen. When I squeeze the handle, the blade doesn't move and the motor makes a sound like it's laboring, but stuck.
There's a little black button to press to lock the blade so you can loosen the screw. Did it get stuck in the in position? Can you turn the blade by hand (unplugged of course)?
I believe the 718 has a belt drive. Could the belt be broken and be buckled or twisted in its case preventing any movement?
Was it left out in the weather and did you get water in the bearings?
Dec 30, 2014 | Dewalt Dw718 12" Dual Bevel Sliding...
My saw makes a loud noice while I'm cutting
I'm wondering what the noise is like. Is the noise only while you are cutting / under load? Is the blade smoking? What type of wood are you cutting?
Jun 21, 2014 | Dewalt 12" Beveling Sliding Compound Miter...
Blade guard will not retract from full closed position. It must be assisted by hand
either cover is distorted and catches or there is build up of saw cuttings/dust preventing a smooth operation,or the assist spring is broken
Nov 13, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
How to change the blade?
I don't know if this will help you much but I've got a DeWalt 14 inch chop saw and a 10 inch miter saw and they both have a small lever on the right hand side of frame just behind blade If you depress this lever and slowly rotate blade until it drops into place this locks the blade for changing. Hope this helps you. Thanks.
Nov 22, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
How do i get guard out of way to replace blade..DW718
Make sure the saw is unplugged, manually move the blade guard up to it's fullest extension, push the arbor lock to make sure the arbor and blade do not spin (on front of saw motor housing), then wrench the nut holding the blade to remove. Remove the old blade, install new one and reassemble in reverse order. You can take the guard off completely if you choose, but it is not necessary. I hope this helps and good luck!
PLEASE REMEMBER TO VOTE AND LEAVE A TESTIMONIAL. THANK YOU
Mar 30, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Need to calibrate my dw708 sliding compound miter saw. How to adjust the slides for a true cut. The blade is square.
i use a framing square off of the back fence with the blade down. when it is square, i check the other side of the fence and loosen the screws on the plate with the degree increments and set it to zero
Nov 21, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Wobely blade
sounds like the bearing is going out on the blade shaft
Feb 10, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Saws Logo
177 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
