Question about Acer Aspire One PC Notebook
Hello, I have an acer one D260 that will not shut down. It remains on even though I continually click the start button and select "shut down" I don't want to turn in off improperly! what should I do? sincerely, emily
  • 21 Answers
Hi, the reason for not shutting down can be anything at first we need to find that reason,
Like if any program that's running and its not getting ended while you press the shutdown, the windows will keep waiting.
1. Try the Clean Boot and check if its shutting down. How to do a clean boot ? as follows.
-Press Windows Key + R then type MSCONFIG and click ok.
-Click on services tab, place a check mark in hide all Microsoft services, Click Disable All then apply.
-Click on start up tab, click disable all then apply and close now restart the computer..its clean boot.
-now check if the system is shutting down if it does, then the programs that are in there are causing it, mostly it will be real time anti-virus programs all the time. So uninstall the antivirus and restart it in normal boot and check. (Normal boot - Press Windows+R, Type MSCONFIG click ok, Click General then choose normal startup click apply > Restart). To confirm the anti virus protection is uninstalled completely open control panel, In security center under Virus Protection make sure it says not found. for XP & Vista its Security Center, if you are on windows 7 you need to look for Action Center instead of the Security Center.
Or you can try the 2nd method too which is easy and will mostly work,
2. Reduce the time in Wait to kill.... Follow the steps as follows.
Press Windows + R Key, Type REGEDIT Click OK.
in Registry in the left navigation pane click on Computer then press Ctrl+F Key, type in "waittokill" without quotes and spaces in the Find box then click Find Next.
Now when it comes up with result it will highlight the string on the right hand pane which will say Wait To Kill Time out Service, double click that change the value data to 20 from 12000 or anyvalue.
So Like this there should be some 5-6 keys. so repeat the above step for all of them like Press CTRL+F and keep searching for all the five keys and change the values for all of them once its done it will says its done searching and it cant find anymore like that.
Try these 2 steps and let me know more information would lead us to quicker fix, Like Operating System you use ? What Antivirus ? like that kind of stuff
Posted on Jan 02, 2011
  • 600 Answers
Open TASK MANAGER --use the key combo of CTRL+ALT+DELETE then choose shut down
Hi! When I shut my computer down the lights do not
When you shut off your PC do you:
1) Give it enough time (could take from 1 minute to 10 minutes) to shut down completely (easy sign is if the fun continues to run or lights are on)?
2) Clicked Hibernate or Sleep OR closed your laptop screen before it completely finished shutting down (this could put the PC to sleep and it would remain on, so the lights would remain on, until you woke it by moving a mouse, flipping the screen back and forth for a bit or pressing the start button (not holding))?
3) Have it plugged in (depending on the model, a light might stay on if it is charging even if it is not on(probably not this one since you said it turns off after a Hard shutdown (don't do this since this damages your computer and will make it break down after continued use)))
Nov 02, 2013 | HP Computers & Internet
When I go to start menu to shut down and press shut down it will just reboot and will ot shut down
Step 1:
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Feb 20, 2013 | Acer TravelMate 2300 Notebook
My apire one d260 does not detect the"network adapter"
In Win 7 , First , Install ALL Windows updates and Acer updates. Shut down the machine and unplug, remove battery, plug in, reboot. THEN, Open the Device Manager, Scan for Hardware Changes. Did it come up at reboot? YES/NO? If no, Select YOUR OS, 32 or 64bit and Download the wireless lan driver at : http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=2438
Jan 13, 2013 | Acer Aspire Computers & Internet
Shuts down immediatley after booting up
I can assume from your description and this "click" sound that you are facing an HDD problem. I would suggest downloading Hiren's BootCD from this link. Burn the content on a disk and boot up from it. Then start some of the HDD tests like HDD Regenerator and examine the results.I hope this helps!
Nov 20, 2011 | Acer Aspire One Netbook
Our Acer Aspire-One, model D260, cannot find wireless connections, even though other laptops in the house access them. the ACER is only 1 week old, and has worked fine until now.
1. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A) Click on the Recovery icon.
B) Click on the Open System Restore button.
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time'
A) Click on the Next button
Now you will find a window with Dates, Description and Type,
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot
Nov 08, 2011 | Acer Aspire One PC Notebook
Bootmrg is missing acer travelmate 2480
  • HI. Welcome to Fixya.
  • Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.Detach any external hardware such as an external hard drive or printerPress the Power button to boot your Acer laptop. Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.Click "OK" in the notice window to proceed with resetting your Acer laptop.Wait while your Acer laptop is reset to factory settings.
    Hope this resolved your issue.
    Thanks for contacting Fixya. Bye for now
  • Jul 17, 2011 | Acer Computers & Internet
    I have an acer aspire one netbook laptop and when I turn it on the logo comes up and then nothing after that what could it be and what can I do to try and fix it?
  • Jul 17, 2011 | Computers & Internet
    I cannot find device manager on the aspire d260 netbook win xp
    If you want to access the device manager you can click on Start select Run a small dialog box will appear on the left part of the screen. Type Devmgmt.msc and it will go directly to Device Manager.
    You can also Right Click on My Computer select Properties. Go to Hardware Tab and then click on the Device Manager Button.
    Thanks for using Fixya.
    Feb 06, 2011 | Acer Aspire One Netbook 8.9" Notebook
    How do I restore my acer to orginial factory settings?
    Hi!
    Before restoring your machine to factory default please make sure that you mback up all your program and files to any external device.
    Please follow the step by step procedure to restore your machine to factory default.
    1. Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
    2. Detach any external hardware such as an external hard drive or printer.
    3. Press the Power button to boot your Acer laptop.
    4. Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
    5. Select "Restore System from factory default" in the Acer eRecovery Management window.
    6.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
    7. Click "OK" in the notice window to proceed with resetting your Acer laptop.
    8. Wait while your Acer laptop is reset to factory settings.
    Should you have any other questions please just leave a comment.
    Cheers~
    Sep 09, 2010 | Computers & Internet
    What button to press to reboot laptop acer aspire 2930
    You turn it off ...then back on to reboot.
    click the start button - select turn off computer
    Mar 24, 2010 | Acer Aspire 2930-4661 Notebook
    Acer Aspire One  PC Notebook Logo
    271 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
