Question about Sylvania G-Netbook
Internet connection and slow - Sylvania G-Netbook
  • 97 Answers
Well, It could be a result of spyware, adware, or a virus infestation. download Spybot, and malwarebytes and run it. you can find them here:
malwarebytes.org
or
safer-networking.org
Posted on Jan 02, 2011
Why does my "hp envy 15-k073ca" drop internet connections?
There can be several reasons why your Internet connection is slow or keeps dropping. To resolve the issue, you can refer to the guidelines mentioned on the link below:
http://windows.microsoft.com/en-us/windows/why-internet-connection-slow#why-internet-connection-slow=windows-7
http://www.wikihow.com/Speed-up-a-Slow-Internet-Connection
GuruAid.com
Mar 18, 2015 | Internet Computers & Internet
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Slow connection
Slow internet connections happen for various reasons, even when you pay for a 'high speed connection'like DSL or cable.Because the internet (and World Wide Web) is built on hundreds of different technologies trying to talk to each other, there are many places where data can slow down before its reaches your computer screen. Your ISP (Internet Service Provider) might be at fault, certainly, but there are many other factors to look at before assigning blame. Some of these slow points are within your control, and can be quickly fixed with a little do-it-yourself effort:
- Refresh your internet connection
- Shutdown your router for minimum 10 minutes so that your back end IP can be change by service provider
- Remove your Temporary files from your system
- Try to use Reginout for constantly refreshing internet connections
Nov 29, 2013 | Acer Aspire 3003WLCi Notebook
Very slow connection speed
Basically the Wireless Internet always slow compared to wired ,also You can use the instructions in user manual,or get that from Online and then connect to Laptop,check any signal problem in wireless router ,better call the ISP to connect it,they will assist you,You can check the speed of the internet at here Scanmyspeed.com it will show Good Speed.
Jan 16, 2012 | Computers & Internet
Graphics of yahoo pages are not appearing properly, it means cannot load any images what can i do pls help me
This because of your internet connection is very slow.
Try wireless broadband connection .
+ OR TRY THIS IF YOUR CONNECTION IS NOT SLOW +
DISCONNECT TO INTERNET AND RE CONNECT TO THE IN TERNET
OR Restart your computer and re connect to the internet.
Mar 24, 2011 | Computers & Internet
Slow internet connection on a 256kbs connection.
Not sure from the description whether this is a router problem or broadband Internet connection problem. If the Internet is slow, this is a good article for finding the source of slow Internet: Simple Troubleshooting for your Broadband Internet Connection.
Feb 21, 2011 | Computers & Internet
Choppy playback, keeps stopping to load
Your Internet connection is too slow.
So, your media-player is getting "starved", and thus must "wait" for more content to be downloaded.
Upgrade the speed of your Internet connection, or connect to higher-speed web-servers, such as YouTube.
Dec 14, 2010 | Computers & Internet
My internet connection is so SLOW can you help me .. !
a slow internet connection can be a number of things slowing it down a dial up is slow .next in your lower tool bar right click select the taskmanager select processes and see what else is running in the background
or you might have a virus or you might have too many programs using the internet at once
hope this helps
Oct 31, 2010 | Computers & Internet
UPDATING MY DRIVERS IS VERY SLOW,WHY?
One of the most common cause of slow updates is slow internet connection. Check you internet connection if it is optimized. Try to test for internet speed at www.speedtest.net to see how fast your connection is.
Mar 13, 2010 | Computers & Internet
Hi, im using a brand new acer asprire x1800 desktop..and i can HARDLY connect to the internet using SUN BROADBAND (lan connection already disabled). i have been using the broadband for a few months now....
There could be several possibilities for your internet connection to slow, or stop functioning. Here is a small list of things to check:
1) Run Spybot Search & destroy:
This is a program that will help you find, and eliminate malware, it's free from Here. It also helps speed your PC up by removing unwanted malware that can drain your system's resources.
2) Check your scheduled tasks to determine nothing is set to run during these " down " times.
3) Check to make sure any wireless connections are secured using WEP or other such wifi security. It's a little known fact that people will " pigy-back " on someone's wifi connection to use the internet and download. this can cause internet instability.
4) Call your Internet Service Provider. Your ISP can usually help you determine if the problem is with your computer or their connection.
5) Check your network settings. Your ISP can help you determine the best settings for your connection, as well you may check to see if the network device has an updated driver from the manufacturer.
6) If all else fails, you may wish to take your PC to a licensed technician, or replace the network device if you feel it is faulty.
In my experience most internet instability that happens on a regular basis during a set amount of time is due to malware, or scheduled downloads.
Nov 03, 2009 | Acer Aspire™ T180 PC Desktop
Sylvania G-Netbook Logo
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
