Im having problems with my hp pavilion a614n it doesnt turn on and it has a blinking light on the power button. i try to turn it on but it just keeps blinking
  • 1153 Answers
SOURCE: green light blinking, tv won't turn on
Look for DM board repair here in threads
Posted on Jan 04, 2008
kgjsm397
  • 105 Answers
SOURCE: blinking green light on the back of hp pavilion
1. Your smps is OK for power supply
2. check the beep sound for RAM and Video card (If it is long beep the RAM is having and short and frequent the Video card) o
3. Remove RAM then start ssytem see the response shoutdown, clean the RAM place it back start the ssytem
4. Remove the CMOS battery or short the jumber for any setting in BIOS start the ssytem
5. Disconnect all the cables connecting motherboard including Hard disk except SMPS power supply to Mother board
Posted on Jun 22, 2008
jtuckerj
  • 59 Answers
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
Joed911
  • 4338 Answers
SOURCE: Power and attenion keeps flashing says turn power off then on
Perform a partial reset of the HP All-in-One
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 03, 2009
nicoleFIXIT
  • 154 Answers
SOURCE: HP Pavilion dv6636nr boot problem
When we talk about laptop won't boot up it is a hardware failure.
First of all, most of the hardware failures that are going to be presented in this article require you to disassemble the laptop and work on its internal components. Because of this, you need the required components to take the laptop apart (such as screwdrivers, etc.) and space, lots of space. If you don't have a workbench, then working on that large table in the living room should do it.
Second of all, you need to be extra careful about ESD (electrostatic discharge). Sure, this is important when working with a desktop system too, but you really shouldn't consider this as some sort of overreaction or waste of time. A few anti-static conductive bags should suffice. These are going to be useful when you take apart components from the laptop and you need a safe place to put them down.
If the laptop does not power on using the batteries, then try to power it using the AC adapter. Pay attention and see whether the LED on the laptop lights up, signaling that the adapter was detected. If yes, then your power jack works. If the notebook still does not power on, disassemble the laptop and remove the batteries. Look first for the CMOS battery and take it out.
Your best bet is that the problem is memory-related. What you need to do is re-seat the memory modules. If there are more than one, then try swapping them between each other and try different slots. Try booting again. If it does not work, then try running with only one module - this way, you can tell whether one is faulty.
Disassemble the laptop and remove the HDD, CD/DVD drives, and the modem and/or wireless card(s). If possible, take out the sound card module (if separate). To minimize the possible causes, you may disconnect the LCD panel as well. Try running this way. If it does boot, then try connecting each connector one at a time, booting up in between to localize the problem.
Good luck and take time to do a hard troubleshooting this trouble is not easy as well. You need to be care full in removing the some parts so that the other will not affected and being damaged.
Posted on Dec 02, 2009
Testimonial: "thanks! i was not waiting long enough before replacing the cmos battery back in its slot. after a ten minute wait, it did the trick. you rock."
I have an HP Pavilion ze4200. It will not even
1. It looks like a battery problem!
2. Plug in your laptop to fully recharge the battery!
3. After 3-6 hours, try to start your system!
4. You can also check by changing the power jack / socket!
5. Is the battery light On / blinking ?
Jan 04, 2010 | HP Pavilion ze4220 Notebook
Pc not turning on led light blinking
check if there is a switch on the back of your power supply if there is try turning off then on again .still no power replace you power supply
Jun 26, 2009 | HP Pavilion A210N (DF210A#ABA) PC Desktop
HP pavilion ze2000 laptop doesnt turn on
Hi there.
Take the system memory out and clean the brass contacts, then reseat the memory and try to boot the PC up again.
The memory is located behind a panel underneath the laptop like this >>>>>> e1bc638.jpeg.
Good luck and thanks for using FixYa!!
May 19, 2009 | HP Pavilion ze2000 Notebook
Thanks, Joe
Apr 30, 2009 | HP Officejet J5780 All-In-One InkJet...
Problems with hp pavilion zd 7000 lights are blinking but it won't turn on
First check to make sure the power is actually on by seeing whether or not the power button lights up or not. If the light isn't on and you have no power try this.
1. Try a simple power cycle. This will correct the problem most of the time. All you need to do is take out your laptop battery. Connect the power adapter and have your computer off. Hold down the power button for about 1 minute. This is done to clear any static electricity that might be building up. Turn on the power button again and the power should come back on.
Apr 14, 2009 | HP Pavilion zd7000 Notebook
Stack of computer hp pavilion 1430 just keeps blinking cannot turn on or off
Can you explain what you mean by "stack"? Is this an external RAID array? Is this a software error message you are getting on screen? If on the other hand you are referring to the box that everything else plugs in to that would be the computer, everything attached to it, including the monitor is a peripheral. If it's the computer that has a blinking light on it and won't turn on or off, it must be on for there to be a blinking light... to turn a computer off manually you need to hold down the power button for over 4 seconds to forcibly turn it off.
Disconnect all external devices such as printers, scanners etc. etc. and try turning it on again, if you get the same problem disconnect absolutely everything including the power cable and hold down the power button for 30 seconds (time it as it will seem to take forever) and try again.
Message back if it's not the computer, just a peripheral your having problems with or if you still get the same problem.
Nov 05, 2008 | HP Computers & Internet
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
