Question about Noma Lawn Mower Ignition Switch Replaces AMFDYNAMARKNOMA 44745
Model e4618-080 key will not shut mower off tracing wires cut 3 wires coming out of engine and still runs?
I have a Kubota lawn mower model RCK60P-28Z that does not start or run. When I turn the key on the lights on the dash come on but the engine does not crank over when the key is turned to the start pos
.It isn't the best quality like a Honda but it is brand new so it will last a long time. As the pictures tell you its in great shape, http://www.rctophobby.com/fr/rc-helicopteres/achete-par-marque/nine-eagles.html,stickers and paint in 99% cond. Asking 150 cash only OBO steal of a deal brand new these things are 300 bucks this thing is brand new cuts just like one.
Nov 22, 2013 | Kubota Garden
Walker mower
Your ignition switch is bad. The contacts inside are not making good connection to send signal to starter solenoid to start engine. Now the run position contacts are bad causing the engine to shut off. If the engine cuts out on you again, wiggle the key in the ignition at the same time start the engine using your screw driver. If the engine starts back up again, wiggle the ignition to see if the engine hesitates and stalls out again. If so, replace ignition switch assembly.
Sep 25, 2013 | Garden
Husqvarna riding mower
The ignition switch takes the coil grounding wire to earth to cut the motor, so there is either a problem with the ignition switch or a break in the earth wire ( check the conections down by the engine ) to check the system run the machine with the deck engaged lift yourself out of the seat, if the engine stops it will be more than likly the ignition switch playing up, if it does not shut down there is a wiring issue.
Jun 20, 2012 | Husqvarna Garden
Simplicity not charging. Just shuts off while cutting grass after a while
there is a connector on the side of the engine that comes from the generator that is under the flywheel see if it is putting out power to there if so trace it back to the loss
May 22, 2012 | Garden
MY CRAFTSMAN DYT4000 RUNS GOOD WHEN THE PTO IS INGAGED WHEN GOING FOWARD WORKS LIKE A CHAMP, BUT WHEN PUT IN REVERCE THE ENGINE WILL DIE, UNLESS I DISINGAGE THE PTO PLEASE HELP ,, GOT THE MOWER USED...
It sounds like your mower is equipped with a reverse safety switch. This switch will prevent you from mowing in reverse by killing the engine, like any safety switch. You just need to investigate it and decide if you will disengage the blades to back up or if you will disable the safety switch. You mentioned that there were wires cut. Do you know what they were? How many were cut? I suggest that you trace them out to see what they are, where they go. The previous owner may not have wanted to deal with the safeties for a number of reasons.
In regards to the reverse safety switch, many mowers do not have them. As in they do not come on all mowers, historically. I do not know if they are designed into all the newer ones or not. I work on older mowers and whether or not they are on a mower seams to depend on the manufacturer (on older mowers). My seven or eight year old Craftsman does not have one, while a twelve year old MTD may.
I hope this is helpful for you.
Aug 22, 2011 | Husqvarna Mcculloch Riding Lawn Mower 185...
I have a Woods Zero Turn Mow n Machine powered
Try taking the cover off to get to the fly wheel and use some fine sandpaper or emery cloth to clean off the magnets on the fly wheel and the two little prongs that set really close to the fly wheel.
My white wouldn't start right away and I did the above and now it starts great.
Let me know if that helps.
Thanks
Roundo4
Jul 31, 2009 | Garden
Mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Mar 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Cub cadet 2135 mower wont shut off with the key
It seems that you have a broken stop wire. Trace the wire from the electronic ignition to the ignition switch.It usually is a black wire.
This is an adjustment problem I think. Make sure with engine off and the unit jacked up adjust the lever that engages the blades. Good tension when actuated and loose when realeased. Hope this is a help to you. donnyb60
Mar 23, 2009 | Garden
Noma Lawn Mower Ignition Switch Replaces AMFDYNAMARKNOMA 44745 Logo
71 people viewed this question
Top Noma Garden Experts
Dennis Key
Dennis Key
john h
Are you a Noma Garden Expert? Answer questions, earn points and help others
