Question about Riccar Sewing Machines
I have inherited a Riccar 829E sewing machine. The shuttle has been loosened on its axle and I am now not sure how to align it so that the needle does not hit it on its downward stroke and so that the needle can pick up the bobbbin thread. Is there a way to know where the shuttle should correctly sit on the axle?
  • 5 Answers
SOURCE: needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Posted on May 29, 2007
kimbo322
  • 10 Answers
SOURCE: shuttle alignment and assembly
The shuttle/race/bobbin system shouldn't really be taken apart by the average user. Unfortunately, your chances of ever getting it back together properly so the machine will sew (this is the timing of the machine) are very slim. You'll need to take it to a sewing machine technician. I would recommend an authorized Pfaff tech as they'll be sure to have the proper tools to do this correctly - won't be inexpensive but will be worth it. Most "neighborhood sewing machine repair folks" don't have experience on computer machines. Resetting timing on a computer machine isn't the same as the old mechanicals and requires some expertise.
Posted on May 04, 2008
SOURCE: Shuttle driver
Hi i have a Janome 350E thread got court undert the needle plate so i cut the thread from under the hoop and got it all out the bobbin shuttle but the machine wont sew now it seams to be out of timining as the needle is coming up to soon for the shuttle to pick up the thread can you please tell me how i can fix it as i dont have a sewing machine mechanic in town and i will have to travel up to 2 hours to get it looked at and they are really slow to get things back to thier clients.
Regards Sandim.
Posted on Aug 17, 2008
SOURCE: riccar sewing machine 8500
I don't know if this will help or not, but here is a website where you can download a manual for any of the Riccar products: http://www.riccar.com/help/manuals/
Posted on Sep 13, 2008
  • 980 Answers
SOURCE: riccar 551 shuttle timing. help
If you email me I will attach instructions drivewithken@blueyonder.co.uk
Posted on Oct 28, 2009
Shuttle case hitting needle
Not good. Alignment is out. Get new needle and adjust accordingly.
Mar 06, 2015 | Sewing Machines
Singer 9116 needle hitting shuttle ****.
Is needle bent? Are the feed dogs aligned? Shuttle clicked in? Is the needle set for zig zag? Could be one of those things.
Best wishes
Nov 11, 2014 | Sewing Machines
Riccar stretch 500fa Needle won't pick up thread from bobbin
Check to make sure you are using the correct needle for the machine, that it is a brand-new needle, and that is installed facing the correct direction. Other than that, it's quite possible the machine was knocked out of time and needs service.
Apr 07, 2017 | Sewing Machines
Riccar Super Strech E21129 364J breaking needles
I believe the number you provided was a serial number and not a model number. When I searched for Riccar Super Stretch it came up with "model 510"
Here's the manual for that just in case it's close enough to your machine that you can get it threaded and such.
http://www.riccar.com/ftp/whitepapers/510-Owners-Manual.pdf
To check the timing of any machine.
Make sure the needle is oriented the way it's supposed to be. Then open the bobbin area so you can see the shuttle hook and needle. (this may mean taking both the bobbin cover off and the throat plate where the feed dogs are)
Turn the wheel by hand until you see that the needle is at it's lowest point of travel. At this point the shuttle hook's point should just be ready to pass the needle scarf. If it is back away from it too far... it is "********"... if it has moved past the scarf it is "advanced." In either of those two positions it needs to be timed. Since I am not familiar with the inner workings of your machine I can't advise you on how to correct timing issues... but if you are a logical, observant and methodical mechanically inclined person, you might see how by really examining the machine. (it may be as simple as loosing a screw or bolt and moving the the shuttle/shuttle race) Take your time and be sure to remember where things go... take pictures if you need to.
Now...Other reasons for breaking of needles are as follows:
Incorrect needle for project. such as sewing denim with a silk or lightweight material needle.
Top tension too tight.
Incorrect threading of the upper threads.
Damaged shuttle or needle plates.
The presser foot improperly installed or wrong foot completely.
Needle positioned incorrectly for presser foot.
Good luck.
Sep 09, 2012 | Sewing Machines
Singer Model 5050 Timing Problem
Actually,timing of needle vs, shuttle is not very easy job several factor you should check on.There is belt ot sometime a shafting with worm gear and helical gear under machine w/c drive the shuttle with the bobbins in timing order,Any one of them is present on the timing adjustment can be done by releasing the belt or the helical gear,besure machine is unplug then set all mechanism on low dead center meaning the needle move to utmost lower position catching this by the shuttle and bobbins at center position.No motion applied if this was set up,engage the belt with pulley and the bobbins link holder tigh allenscrew besure the needle is lower dead center at the center of shullle bobbins catching needle without motion when setting back at original position.If this was made manually move it on handwheel going up and side down the needle gradually if the needle move freely several time and it was catching this by the shuttle hook bobbins.if ok put thread bobbins and upper thread dial tension with the needle.Move machine on handwheel try to catch the bobbins thread,If this so your machine is ready to sew again if problem occurs on alignment repeat adjustment on perpect alignment,besure all parts on upper casing of machine specially two drive gear are in normal alignment.
Mar 15, 2009 | Singer 5050 Mechanical Sewing Machine
Shuttle alignment and assembly
May 02, 2008 | PfaFF Creative 7570
Riccar sewing machine 8500
Feb 26, 2008 | Sewing Machines
Sewing Machines Logo
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Derek Massey
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
