Question about Patton PFH5505HD-U Compact Heater
My Patton PRH700 air heater made a click noise and stopped working. Is there a fuse or something I can replace on it to make it heat up again?
5 Suggested Answers
  • 5 Answers
SOURCE: 2000 watt baseboard heater is making loud clicking noise
Hi
You do not give details as to the material the heater is made of.If we presume the backing is made of metal then the heat is deforming the metal and being screwed there is no expansion.Also why is the heater on the ceiling.Dust and other grime will give a smell-keep it clean.
Hope this helps
Jay
Posted on Nov 17, 2007
SOURCE: Patton ceiling heater Model# 2433
x48987
Posted on Jun 09, 2008
  • 9 Answers
SOURCE: I have a small space
Not worth fixing. Take $20 and buy a new one.
Posted on Jan 20, 2009
heatman101
  • 43501 Answers
SOURCE: my Patton PUH680 space heater is not working. Do
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Posted on Jan 16, 2011
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
I have a Patton Heater ( Brand New ) that was given to me. when I plug the heater in it lights up but the heater or fan does not come on. This heater has never been used. What could be causeing this?
Try spraying a LITTLE WD-40 on the fan bearings, with the heater unplugged, of course. You may have to remove the case to get access. Before you spray, try to spin the fan with your finger. Spray then try again with the finger. I think this will do it. If you don't have WD-40 ... try sewing machine or other light house hold oil.
Thanks for visiting today.
Jan 27, 2011 | Patton PUH680-U Utility Heater
My Patton PUH680 space heater is not working. Do you offer replacement coils?
heatman101
Dec 06, 2010 | Patton PUH680-U Utility Heater
What is the lowest temperature I can maintain with this heater ? That is, I plan to use it in crawl space where water pump and pressure tank and copper pipes and water heater are located and in winter...
YOu are asking a question that cannot be properly answered without knowing more of the situation. If this crawl space is subject to large air drafts and there are air vents that allow openess to this area, then you cannot be sure of the results. Since it will be winter, the humidity build-up is not so much a factor and you should take steps to isolate this area from air movement. Then you can apply heat. You may want to make a temporary plywood barrier around this area so your heat stays confined, thereby using the minimal heat needed to keep the temp you want. The heater will most likely handle the job; you should get a thermometer and keep the space at 40 degrees farenheit or slightly higher. When the warm weather arrives, remember to open the air venting again.
Oct 11, 2009 | Patton Electric Patton PUH680-U Electric...
Heater in dash makes clicking noise, stopped no heat
The clicking noise you are hearing is the temp door actuator. It is located in the center of the dash. If you look behind the radio from the Passenger side of the van you will see a white square box with a black or green connector in it. Remove the connector and then remove screws that hold the actuator in place. Install a new actuator and reconnect the wire connector. This should take care of your problem and your heater will be fixed. I hope this was helpful.
Jan 02, 2009 | 2003 Ford Windstar
When the alarm on the Patton Electric Heater sounds, whay does one do to fix that?
This heater was the determined cause of my total loss house fire. I thought the company would atleast help me find some where else to live, they seem to care. But, as of lately they are doing nothing.
I am told this heater-(prh11- 2008 model- purchased at walmart for about $27.00)
- Had wiring that wasn't up to standards
-1/10,000 units cause fires
-something wrong with the heating element-stops working
- wouldn't stand level
-heating coils
-fires like mine have happened to a few other people
This came directly from a person at Jarden corporation(aka patton-sunbeam)
Jan 05, 2008 | Patton Electric Patton PUH680-U Electric...
Space heater will power up, but not start,
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
Mar 28, 2007 | Patton PUH9000-U Heater
Patton PFH5505HD-U Compact Heater Logo
151 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
tractorman44
tractorman44
Jay Finke
Jay Finke
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
