Question about Dishwashers
Fridgeadare FDB510LCS5-My diswasher does not appear to be draining. The bottom of the diswasher is full of water.
  • 24 Answers
There is only a few things this could be caused by
if it is not obvious like a clear plastic wrap covering the drain ports on the base insdie teh dish washer then it will have to be one of the following:
check these:
1. Drain line/air gap
2. Pump
3. Drain valve and/or solenoid
4. Belt
5. Motor
6. Timer it is highly not likely to be the timer..
GL
Posted on Jan 02, 2011
My asko 3122 dishwasher wont drain
It is likely that there is some minor clogging in the diswasher drain filter.Clean as per the user instructions available with the dishwasher. Also likely the kitchen drain could be clogging. Buy a dishwasher cleaning kit from supermarket. Finish make a good product. Use it to clean the dishwasher as per instructions on the kit.
Nov 27, 2012 | Asko Dishwashers
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
The water is not draining at the end of the dry cycle. White dirty water pools in the bottom of the diswasher.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 02, 2011 | Dishwashers
The bottom of the diswasher is full of water after the cycle
Since the drain pump will pump the water out using the "cancel/drain" button, if it did not work then your problem is likely to be in the drain hose system or the garbage disposal downstream from the drain pump. Check for kinks in clogs in the drain hose. Grease can build up in the portion of the drain hose just before it attaches to the garbage disposal.
Oct 01, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
My Maytag diswasher leaks from what appears to be just above the bracket that holds the motor
hello mam please check the drain line if the line is having cracks please change the drain line and if the water is leaking from the bottom of the washer then change the 'o'ring which will be inside the dishwasher to fix this ring you should remove the drain line.
Oct 24, 2009 | Dishwashers
Diswasher has water standing at the bottom after the dishes are clean
Some water can be normal. If it is too much the drain line is clogged or the drain tubing may be too low going into the drain under the sink. Raise the tubing to 30 inches before it drops down and goes into the sink drain. Read the install manual.
Aug 26, 2009 | Dishwashers
Water won't drain after cycle is done. Leaves 1-2 inches of water in bottom. Checked hose and its clear. Put hose going to disposal in bucket and water comes out when diswasher is cycling
it is easy track this path of water from bottom of m/c it will b afilter then small hoses to drain pump thenouter hoses <
thanks
Jul 13, 2009 | Dishwashers
Water not draining from dishwasher
1.attache the drain hose to the bottom of contertop.
2. drain back valve is not work properly.
Dec 20, 2008 | Whirlpool Dishwashers
Diswasher
Check the float switch. If it is stuck the machine will start but no water will be allowed in and the pump will turn on to drain the non existant water. This happens often when a small item gets under the float preventing it from allowing the water valve to open. Find the float in the bottom of your machine and make sure it moves freely.
Jan 15, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwashers Logo
128 people viewed this question
Top Dishwashers Experts
