Microphone does not work I have disconnected it, then connected it back up but no better.I have also turned the tv off completly then powered it back up but to no avail. Thanks Kevin.
  • kevin817 Jan 03, 2011
    Sorry
    I may not have made myself clear,the microphone is part of the camera (Panasonic TY CC10W) which plugs directly into the USB port on the tv (Panasonic TH P42V20Z).
    Your comments please
    Many thanks
    Kevin
  • kevin817 Jan 05, 2011
    Hi
    Dont go any further with this, Panasonic NZ is going to replace the camera. Thanks anyway.
    Kevin.
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Hello
Will you please send me details and descriptions about your TV. You haven't specified anything about it through your post. Which is the Brand, and what is the model number. Give me details through Fixya please.
Posted on Jan 04, 2011
  • 17,129 Answers
To start with you might need to check the microphone individually to see if the Microphone works. So have the mic impedance checked with a meter. If this is disconnected you can test the coil resistance and the line continuity.
Use the mic with an amplifier to confirm that the mic works well.
Now check the input of the mic and specially the audio amplification of the unit. You must be able to attain a good audio output with the touch of your finger on the input port. if not the amplifier can be faulty and must be checked. It can be failure of power to the output or a failure of the amp.
Since the model and make is not specified I would be able to help you more with some details after you have checked these tips.
Posted on Jan 03, 2011
  • Donald DCruz
    Donald DCruz Jan 05, 2011
    If so the camera must bedetected on the TV. If detected without any the mic being ON, record a visual with sound and try to play back. If the sound is heard then the camera should be fine. If so the manual must be checked again to see if the mic works when connected as a web cam. so check this out.
Sony Bravia built in DVD player wont accept the discs - why is this?
Performing a power reset
1. Turn off the television.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
How to establish an HDMI connection between a TV and other device.
Follow the steps below if the HDMI® connection between your TV and other device is not working:
1. Make sure both the TV and other device are turned on.
2. While turned on, unplug the power cords for the TV and device from the electrical outlet.
3. Disconnect the HDMI cables from the TV and other product.
4. Wait 60 seconds.
5. While the HDMI cables are disconnected, plug the power cords back into the electrical outlet.
6. Turn on the TV.
7. Re-connect the HDMI cables.
8. Turn on the HDMI-connected product.
The TV should now detect the HDMI signal from the connected device and operate normally. If there is still a problem, disconnect the HDMI cable from both products and then reconnect it in the opposite direction. In some situations this has been reported to resolve connection issues.
How to reset a TV to factory settings: https://us.en.kb.sony.com/app/answers/detail/a_id/61396
Hopefully this post helps you! If does, please mark it "accept as solution"
Aug 20, 2017 | Sony Televison & Video
Having problem with powering up tv
Hi John,
Power board or any other board is to be decided only after proper examination and voltage measurement. Your tv is trying to" power on" but due to some problem the action is not completing. Better consult some good TV technician.
Good luck.
May 06, 2015 | Vizio Televison & Video
Why does my tv shuts off soon after its turned on?
The Sceptre is a fine TV but is very sensitive to power surges.
If the unit turns off, soon after powering on, it is most likely the power supply.
Try disconnecting the power to the unit for 20 minutes and allow to completely cool down.
Re-connect the power and try the unit.
Hope it works for you
May 23, 2014 | Sceptre 32 X320BVHD 32 LCD TV
I disconnected and reconnected the cobra 29 nw ltd classic and now my voice is heard very low and slow it was working fine just before disconnection. can you help
How did you disconnect it?? Antenna wire?? Power supply?? Microphone?? May be that you have a short in your coax in back of radio. Try taking it loose and screw it back in. Try new coax. Turn up Mic gain knob or change microphone. Make sure power wires are connected RED to RED(+) and Black to Black(-). Try grounding radio to metal ; if inside house ground to metal water pipes, filing cabinet, breaker box or meter box or 8 foot rod into earth. Measure SWR it should read 1.1 to 1.5. Measure power supply with Voltmeter it should be 12 to 15 volts. Check antenna plug in back of radio is my guess or microphone itself.
May 09, 2011 | Cobra 29 LTD CB Radio
I press the power button and the television will not come on. The light switches between blue and red as if there is a short-circuit or disconnect or its thinking.
Hey there! I had the same problem 2-3 weeks ago. The TV won't turn on, although there is a blue light.
I called the service centre and they came and found out that a cell that connects electricity to the LCD screen is dead. So they had to change the whole board. It costed me around $135. Then, everything went completely fine. Works better than ever.
I wish that I helped you & that this post helps you at most! Don't forget to rate! :)
Jan 14, 2011 | Polaroid 20 in. EDTV-Ready LCD TV
Sony 46" lcd turns off by itself and will not power up again.
if your tv unit is still under warranty, first you better bring it back again to the store you just bought it for warranty purposes, your tv has an internal problem, maybe manufacturer defect. Usually the cause of that is a shorted electronics component, say for ex, a mosfet transistor that is located at the power section, or maybe a capacitor that is leaky, and also an open resistor. if you don't know how to troubleshoot this problem, you better have your tv unit repaired by a professional tv technician.
Good luck
Jan 22, 2009 | Sony KDL-46S4100 46 in. LCD TV
Itunes connection
yes they are lost and you would have to turn on write protection. better idea is dont use itunes invest in a better online catalog.
May 18, 2008 | Tascam DP01 All-In-One Recording Package...
My lt37hvs turns off by it self
I have the exact same issue. Some days I can play halo 3 online for ~8 hours and have no problems, but other days it just powers off and I have to leave it unconnected from the outlet for 3+ hours.
For those with the same problem looking for a better fix, do not leave the TV on to just idle on a pause screen or something of that nature. Try to get the HDTV an outlet with nothing else connected to it. Finally, putting a big *** floor fan cooling it down does seem to help. The TV is great considering the price and quality of the picture, but the issue makes it absolutely worthless in my mind. What's the point when you can't use it when you want to? Ugh, despite the great price of $600 for a 26" 1080i HDTV, I'm going to go with a Japanese HDTV next go around.
Apr 28, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Kenwood 606 receiver
disconnecting the tv from the audio connections on your amp may have created a powersurge in the audio input selector IC. Try powering down the amp at the wall completely for 5 mins and turn it on again. Check to see if operation has returned. If not then it may need an audio selector chip replaced.
This problem can be caused when connecting or disconnecting rca connectors from non earthed equipment like TV and VCRs, By the nature of this type of connector, it will spike the input line by connecting with voltages floating often over 100volts.
to avert this problem occurring, wire all the equipment up and with aerial disconnected and tv / vcr turned off at the wall socket. Turn the equipment power on at the wall last thing.
Dec 14, 2007 | Kenwood VR-6060 6.1 Channels Receiver
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
