Question about Asko 24 in. D3250 Built-in Dishwasher
I need to order a new silverware basket for my Asko D3250 dishwasher. Can you tell me where I can order one from? Thanks, H. Burns
yalmer
  • 552 Answers
SOURCE: melting dishwasher basket
I need to know what make and model to tell you if anything can be done.
Posted on Feb 11, 2008
  • 1891 Answers
SOURCE: Our Asko D3250 dishwasher is brand new, and it
this sounds like a improper install ! ck to see if the drain hose outlet is lower than bottm of tank. it should drain to the disposal . and have a drain loop under sink .. the dw prosser is sensing that the drain is longer in time so it flasher inlet fault . . elevate the drain and try again ..if it drains to a lower use a stand pipe or a siphon brake . in the install .. mm
Posted on Dec 03, 2009
Testimonial: "The drain is working. It fills but doesn't start the washing, just comes on with the fault light. Could it be a faulty control panel? Or ???. Thanks."
Macmarkus
  • 2605 Answers
SOURCE: replace upper basket and bearings on Asko
Welcome to FixYa.
Yes the upper rack is pretty straight forward, but the bearings are tricky.
Here's what works for me, move the rack stops to the left if you haven't already and then the rack itself.
i.e.
1d854c5.jpg and
Now you'll need to remove the bumpers at the back of the rack rail...
i.e.
push down on the bumper as shown
and pull it down and out at the same time...it takes some force as evident by my finger tip ha ha, you can use a small screwdriver...I'm just stubborn.
Now you'll need to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in place while removing the rail...
The trick now is to install the balls into the holders first...
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done.
Thanks for visitng "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
I should also mention you as I alluded to, be sure none of the old 8 ball bearings didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Again, good luck :)
Posted on Sep 23, 2010
SOURCE: Hi, I have an ASKO
I have exactly the same problem. Did you learn what this part is?
Posted on Oct 26, 2010
Macmarkus
  • 2605 Answers
SOURCE: d1776 asko dishwasher upper basket
Hello, welcome to fixya
i.e.
and
i.e.
and pull it down and out at the same time...it takes some force, you can use a small screwdriver.
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here )
Hope that explain it for you or gives you an idea of how it needs to be done. Please take a moment to rate the assistance I provided here today favorable and a brief testimony is also appreciated when providing free solutions.
Thanks for visiting "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
Posted on May 16, 2011
Replacement silverware tray
Best Dishwasher Replacement Baskets - Amazon.com
www.amazon.com/...Replacement-Baskets/.../2232353...
Amazon.com, Inc.2. GE WD28X265 Dishwasher Silverware Basket · 4.6 out of 5 ... Whirlpool 6-918873Silverware Basket · 4.7 out of 5 ... 4. Whirlpool 8531233 Silverware Basket.
Nov 24, 2015 | KitchenAid Architect? II S SERIES KUDS03FT...
I have an ASKO D3251. Door free falls when opened. No longer has tension to control downward movement.
Your springs are faulty.you have two of them and will need to pull the unit out and inspect.usually on asko dishwasher you have to order the whole tension spring assembly .
Jul 29, 2012 | Asko 24 in. D3250 Built-in Dishwasher
The basket at the bottom of the dishwasher has water in it, is this a plumbing problem?
as the dishwasher ages and broken glass, coins, ect get in the bottom the impeller that drains the water out gets worn and doesn't work as well. The other cause could be that the drain hoes is partially clogged.
Feb 02, 2010 | Asko 24 in. D3250 Built-in Dishwasher
ASko D3250 fully integrated - hotsteam/water swelling joinery
check the area of leak sounds like seals gone on dishwasher see if seal can be put back into groove posistion
Aug 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Asko D3250 not working
If the first start button is blinking then there is a door error...the door switch is not closing... to repair
1) turn off the power at the breaker...
2 ) remove screws in the door T20
3) remove contol panel (slide up)
4) place wire tie behind micro switch on door latch...
5) replace door latch and door.
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 25, 2008 | Asko 24 in. D3250 Built-in Dishwasher
ASKO D3250 Does not run
HI thanks for your question. the problem is with the water pump. its electric, so some of the food got caught in the pump. clean out the pump. thanks, the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Asko W6661 Front Load Washer
Asko dishwasher d3250 door not closing
the door latch is faulty or needs to be rolled open
Jul 08, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
Nov 17, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 24 in. D3250 Built-in Dishwasher Logo
246 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
