Question about Gaggia Titanium Espresso Machine
Hi My gaggia titanium is not frothing milk correctly. I've descents but that has still not solved the problem It's sounds like it's spitting Thanks
    President:
  • 1,618 Answers
Try this remove the parnello wand and open the valve if you get a nice burst of steam then the problem is in the parnello wand, if you get the same spitting, then there is something in the valve or the steam boiler that is preventing the proper flow of steam.
Posted on Jan 05, 2011
  • chrissy_stap Nov 14, 2015
    Clean the wand and there is a small hole at the top get a pin and unblocked the hole I've done it makes a difference
Hi, the steam from the wand is not frothing the milk like it used to, hardly any froth at all.
If the frother is warming the milk, but is not frothing, then you want to make sure the panarello is clean.
Slide the cover off the frother and check the pin hold on the top edge of the cover. If this hole is blocked the milk will not froth. Rinza is great clean to help prevent these issues. http://www.cerinicoffee.com/rinza_urnex.asp
Also recommend frothing water instead of milk to clean the frother well.
For more information visit: http://www.cerinicoffee.com/Coffee_cleaning_supplies.asp
Jun 07, 2011 | Gaggia Brera Coffee Maker
Frothing attachment coming off from pressure
Check the holes in the attachment they might be blocked and the pressure of the steam is blowing it off.
Apr 14, 2010 | Gaggia Classic Espresso Machine
The steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Feb 13, 2010 | Gaggia Titanium Espresso Machine
Milk not frothing
You require a new frother
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Hot water doesn't have enough pressure to froth the milk. descaled but still no froth! Thank you
If you have no steam then it is possible that the steam booster boiler is damaged, or the thermostat tripped.
Jan 11, 2010 | Gaggia Titanium Espresso Machine
No steam when valve opened, spits out water in the beginning of frothing
There is a small teflon piece on the inside of the steam tube, you will have to disassemble the frother to get to it. Remove this piece. Reassemble and the wand should work fine.
May 08, 2009 | Gaggia Syncrony Compact Coffee...
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Losing steam
Try to descale the machine to see if will be better.
Aug 13, 2008 | Gaggia Classic Espresso Machine
Milk is heated but doesn't produce adequate froth
Inspect the end of the frother nozzle you should see a small plastic piece protruding.
If you dont see it remove the lower half of the frother and insert a pen and push the plastic insert to the end of the frother.
A "click" should be heard when it is located correctly.
Feb 21, 2008 | Gaggia Titanium Espresso Machine
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
361 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
