I have a pepper jamb problem.How do i fixed it?I can't remove the drum.
  • 24 Answers
A make a model would help .. all of them are different and if you can;t remove the drum what is a drum on a printer? usually there is a button that releases the top from the bottom and the paper jam will be in the middle and easy to remove.. like a sandwich take out the meat..
Posted on Jan 02, 2011
Salt and pepper grinders how to clean
warm soapy water, you can put some soapy water in the grinder, shaker and shake it vigorously to remove any pepper or salt that is stubborn, but hot water will dissolve the salt and loosen the pepper.
Sep 29, 2014 | Cuisinart Salt and Pepper Grinder,...
What are the differences between red and green peppers?
The main difference between these two peppers is the taste. Green peppers are bitterer than red peppers. This is because green peppers are picked out before they are fully matured. Red peppers are known as sweet peppers. More over, red peppers contain much more vitamin c and beta-carotene than green peppers.
Jan 17, 2013 | Cooking
Paper keeps jamming
When you remove fix a paper jamb make sure all the pieces of paper are removed, if not it will cause continuous paper jambs.
Sep 26, 2012 | Dell Office Equipment & Supplies
The drum on my Hotpoint WMA454 appears to be jammed, it only moves a small distance without resistance. The belt is attached and ok and there is no noise as if it is the bearings, just won't move.
What you have probably got is an article of clothing that has found its way in between the two drums. Remove the belt without forcing it then carefully retry and rotate the drum. If spungy, yes something is stuck between the drums. Shortest possible way to remove the obstruction is to remove the heating element and carefully look into the hole once element is out. 90% of the time the clothing is jambed around the element. Use long nosed pliers or a wire with a hook and remove. Retry and turn drum. If free to rotate, replace element and retry once all is assembled.
Aug 03, 2010 | Hotpoint WM56 Front Load Washer
How do i repair my maytag from squeeking
remove the front exterior panel. The seal around the drum must be clean and have no crease. If so the seal will produce a sqeek. Also the belt around the drum must be tight and the roller bearing on the belt tensioner must turn freely. If the roller is out of round the drum will rumble and if the bearing is dry or jambed the dryer will sqeek as well
Feb 06, 2010 | Dryers
The copier makes it half way thru the copy the stops with a paper jamb usually on the print table. I keep having paper jamb issues also have finger prints on copies which started after I removed the toner...
The jamming with the copy half way thru is almost always a broken fuser drive gear. The unit that gets hot as the paper exits the machine. Check the back side of this unit. You will see a gear, or part of a gear that is about 1.5 inches across. Either that gear breaks or the cog inside of it shears off and this causes the fuser not to turn. Very inexpensive part at less than $15 and pretty easy to change.
As far as the fingerprints go you most likely touched the drum surface. You may have to remove it again and clean your fingerprints off the drum with a soft cloth.
Oct 20, 2009 | Xerox Office Equipment & Supplies
Drum often need manual turn before it starts to turn
Tumble dryers dont have brush motors they are started by a capacator which will be on or around the motor.
It is about the size of a pepper pot with wiring to it.
These are cheap to buy and if the drum turns after you give it a push then this is the culprit.
Hope this helps & thankyou for using Fixya.
Jan 19, 2009 | Dryers
E04
Thre is problem with drum assy .may the speed of drum is not correct.try to replace with a new one.
Nov 27, 2007 | JVC COMPACT VHS-C CAMCORDER
20 people viewed this question
jasbo
jasbo
