Question about HP PSC 1510 All-In-One InkJet Printer
Print cartridges pop out: wont stay in
I changed the print cartridge and now the new ones won't stay in they fall out.
    Novelist:
  • 105 Answers
When you push the cartridges in, they need to *click* into place for the machine to hold them. It sounds like you're just not pushing them in quite hard enough. HP is pretty consistent in making the holder a little stiff so the cartridge locks in tight.
If you have the user manual, the instructions for replacing the cartridge are on pg 43 (pg 47 of the pdf file). If you don't have the manual, you can download it at:
http://h10032.www1.hp.com/ctg/Manual/c00366227.pdf
Posted on Jul 22, 2008
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have changed the black ink cartridge and although it is o.k. the black wont print. help I have taken the cartridge back and changed it to check if its ok I have cleaned Please help urgently
Hi
If it is a original HP cartridge try running the inbuild cartridge clean and if that does not work you can get a replacement cartridge from HP if it falls under there warrenty agreements if it is not a genuine hp cartridge I suggest go and get yourself one. Also by using generic cartridges in these systems and mess up the ink systems of the actual unit
Peace
Nov 26, 2009 | HP Photosmart 3110 All-In-One InkJet...
Black wont print. Changed to new cartridge, nothing
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Office Equipment & Supplies
Printing with no ink
1. Lift the front cover, and wait for the printer to move the old cartridges forward.
2. Take off or pull the clear plastic tape off of the back of the cartridge.
3. Pop the cartridge holder off of the top of the cartridge you are changing and pull the old cartridge out.
4. Carefully insert the new cartridge into the holder until it snap in place.
5. Close the front cover.
6. Your printer will automatically recognize the new cartridge.
7. Try to print a test page.
Oct 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Wont print saying low ink even tho just changed it made sure cartridges were in correctly and wont scan either will print in color but not black ink even tho new ink cartridge
A few basic causes.
1. The cartridges you bought were not original equipment ones (OEM)and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printer through the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
run the cartridge alignment process
If you are filling them yourself then...
Cartridge ink levels are usually monitored by a small chip on the cartridge. If that cartridge is allowed to fall below 25% ink level most chips then become locked and not able to re-set.
For many cartridges you can buy a reset device to reset chips that have not become locked. Or you could buy empty cartridges that don't need resetting and that will always accept a self refill.
As for scanning if by that you mean the photocopy function then that could be linked to any of the above. But should you mean it wont scan to the computer then you should look at any hardware or driver issues that you may have and maybe also the source selection (usually TWAIN) is a good source selection.
If this information was useful please click below
Aug 18, 2009 | Canon PIXMA MP210 InkJet Printer
Printer wont Print after replacing catridges
1. Make sure the printer is switched on, the old cartridges are still in the printer, and the cartridge cover is closed.
2. Click on Start, Programs (XP: All Programs), Lexmark <Printer Name>, Lexmark <Printer Name> Solution Center.
3. When the Solution Center screen appears, click on the Maintenance button on the left-hand side. (This button is the third from the top and bears a picture of ink drops.)
4. When you see the Install or obtain a New Cartridge option, click on it once. A pop-up displays a brief description of how to physically remove an old cartridge and install a new one.
5. Follow these instructions and click Next. The software will prompt you to confirm whether the cartridges are new or old.
6. For the new cartridge you just inserted, select No, it's new. Important: Make sure the setting for any old cartridge stays on Yes, It is old.
7. Once your selections have been made, click OK. The program will want to run the alignment for any new cartridges you installed. This applies whether you changed one or both cartridges (in the case of printers that can hold two cartridges). An alignment screen with a red and white bull's eye will appear.
8. Make sure the cartridge cover is closed and that there is paper in the printer.
9. Then click the Print button on the alignment screen. A sheet of paper will print from your printer with a series of arrows and numbers on it, with one set of solid bars above them. You should see four groups of lines, unless you have a single cartridge. If you have a single cartridge, you will only have one set of lines.
10. In each group, locate the arrow that looks the most solid. It may help to circle the number under each arrow you choose as you go along.
11. On your screen, you will see an area where you can enter the alignment values. When you have identified all the numbers, select those same numbers for each group on your screen, using the up and down arrows next to each value for A, B, C, and D (or A if you have only one cartridge).
12. When all the numbers have been changed to reflect the chosen numbers on the printed alignment page, click OK. The cartridge installation procedure is complete.
13. You can now exit from the Solution Center.
Source: micksmixxx
-Yahoo Answers
Please tell me if this helped I take no credit as I used the name aboves solution any credit should be give to him
Jan 07, 2009 | Lexmark X125 All-In-One InkJet Printer
Changing Cartirage
It should not come all the way out. Just till it stops, then the new cartridge locks onto the top of the hopper. Once you have pulled out the shutter, the toner falls into the hopper. Pushing tghe shutter closed causes the cartridge to pop up in the front so it can then be removed and thrown away, the cartridge does not stay in the machine.
Jun 19, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Replacing ink cartridge
OKay, first, you grab under that control panel, you know, with the COPY, SCAN, PRINT, etc buttons? So you lift it up, and the whole top of the machine goes up. Wait a bit, and these cartidges should pop up. So grab the cartridge you wanna remove, and pull slightly down on it, and it should come out. Then, slide in the new cartridge slightly upwards, and viola! it should slide in. THen, close the top, and you have changed the ink! YAY!
Apr 08, 2008 | Office Equipment & Supplies
HP PSC 1510 All-In-One InkJet Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
